Hi Folks
I have an D21 with an SD25 in it. 2wd with a 5 speed manual tranny. I have a spare motor as well.
I had the transmission rebuilt last year in Port Alberni B.C. and it just jammed in 3rd gear. I managed to get home in third, but only just squeaked over a couple of the mountain hills. When I got home and checked the oil there was NONE!
I am not sure I want to spend another $1000 (or more) on yet another rebuild so am wondering if anyone knows of another transmission that would go in there without redesigning the truck. Would one work from another year and from a gas engine model? I'm not too worried about gear ratios, though I do like what I have now. The big thing is whether it is the right length and/or can mount to the bell-housing.
Nissan dealers tell me that it is specific to that vehicle, but they often don't know much about these vehicle and are only going by what the book says "is recommended" for it.
Perhaps there is a Toyota or other make that would be useable?
Niseamer
I live in Ucluelet, B.C. Canada (west coast of Vancouver Island)
d21 SD25 Transmissions?
dn29626
niseamer
d21 5 speed transmission swap
Thank you so much.dn29626 wrote:The front section of the five speed transmission (diesel and gas) will interchange between a gasser trans and a diesel trans.
Do not damage that front section of the diesel trans. It is the hard-to-find part.
This makes my decision a lot easier! I got the tranny sitting on the ground today...I can see it will be a lot harder to align everything for the install though..it seems to be a tight fit for a backyard mechanic with minimal jacks etc.
I will treat the front part of the case like fine china!
Cheers
Gerry
dn29626
These links will help.
http://720world.com/forum/topics/how-to ... nt%3A70991
http://720world.com/page/featured-links-1
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
Anderson , SC
Since Fall 2009
niseamer
Re: d21 SD25 Transmissions?
In case anyone is interested:niseamer wrote:Hi Folks
...... wondering if anyone knows of another transmission that would go in there without redesigning the truck. Would one work from another year and from a gas engine model? I'm not too worried about gear ratios, though I do like what I have now. The big thing is whether it is the right length and/or can mount to the bell-housing.
Niseamer
I got another transmission (FS5W71C) from a 1995 Nissan gas pick-up.
I switched the bell housing from my truck. Put it all together and tested yesterday.
I was told the transmission would have to come from something before 1993, but this one works fine.
Everything fit in perfectly and the transmission works well. I was unlucky enough to get one with a little higher gear ratios in the lower end, which means a higher 1st, 2nd and 3rd gear are higher. I am not sure that 4th and 5th are higher though....I don't have a tach.
I would like to have a lower 1st and second though....such is life.
I also put in a different SD25 since the other one was getting little tired with over 500,000 km on it (though is still ran fine). This one has an in-line pump rather than the rotary on the original. I does have a bit more power and does get better mileage. One three hour run got me 43 mpg (imperial), though I am skeptical about my math on that!..seems pretty high except that I did get up to 39 mpg on my older engine once. The older one averaged about 33 mpg, whether running on veggie oil or diesel.
After a bit of testing I will be adding my old veggie oil system to this one as well.
So far I am happy with both the transmission swap and the engine....
Hope this info is helpful to someone pondering this swap as well. Open to questions etc......
Thanks to everyone for their help on this.
Cheers
Niseamer
