I got my injectors rebuild and went to adjust my smoke set screw and it broke with very little force. I imagine that it was already fractured somehow.
Does anyone have a clever solution to this? I know there is a spring and a pin inside. I was thinking I may have to go to a machinist to have one made up for me. Perhaps someone has a cannibalized inline type pump lying around that could spare the smoke set screw?
Any advice would be greatly appreciated...
Thanks!
Broken Smoke Set Screw...
Re: Broken Smoke Set Screw...
That kinda/really sucks. Not sure of a solution for that.
Perhaps a pump re builder has one lying around.
I'm not that certain as how that screw is configured on the inside and if it can be simply screwed all the way out to remove it or if there is something on the inside that
#1 May prevent it from coming all the way out or
#2 Will "disengage" with something on the inside. ( really really sucks )
Good Luck
I am sure there is an exploded view of a fuel pump on here somewhere that may show just whats involved in changing this.
Keep us posted
Good Luck
Keep us posted
Driftwood wrote:I got my injectors rebuild and went to adjust my smoke set screw and it broke with very little force. I imagine that it was already fractured somehow.
Thanks!
Is this what you are looking for, if it is PM me if you want a reasonable response time wise, I live across the river from you in Vancouver.
Does that screw go here:
Yes, that's the screw. Ended up obtaining one from Wayno in Vancouver.
Thanks Al,
Driftwood
Thanks Al,
Driftwood
Users browsing this forum: Ahrefs [Bot] and 2 guests
