I am considering putting a LD28 into my Nissan Patrol, which currently have a carburetor L28 petrol engine. As far as I know both engines use the same mounts, same drivetrain (4 speed) g/box and differentials). What I probably need to think of is if the same fuel supply lines and gas tank can be used. I have no experience of converting to a diesel setup and what will be required, but I do know the petrol engine setup well, as well as have general mechanical knowledge of the Datsun cars. I can get a complete LD28 imported from Japan, for not much money, and the friends with the local Nissan technicians who are very skilled working on the older Datsuns. I always liked the diesel. My dad had a Nissan Cedric 2.8 diesel, mated to a auto box. Loved that car...
Can someone on this forum give me some pointers to think of when considering this type of conversion? Thanks
Swapping LD28 into a Petrol L28 Nissan Patrol MQ 1984
Re: Swapping LD28 into a Petrol L28 Nissan Patrol MQ 1984
I recommend reading "LD28 into Astrovan" in the Users rigs section of our forum. Details installing the LD28 into a former gasoline vehicle. You'll need diesel fuel filters and water separator and complete glow plug activating device, there's a universal set-up on E-Bay. I think different motor mounts also from the gas engine. By the way, do you mind mentioning the cost of the imported engine? Just curious. Duane
Duane
