Hello everyone.
Both the left and right turn signal and emergency flasher are not working. Any suggestions on what to start looking for first?
Turn Signal and Emergency Flasher not working
Re: Turn Signal and Emergency Flasher not working
The multi function switch on the top of the steering column where the 4 way flashers are activated. That would be where I would start.
Thanks plenzen for the tip. Took the steering column cover off and pulled the electrical connections apart and cleaned everything up with some compressed air and everything is working now.
