buckshot wrote:Don,
In answer to your question Yes, I have loosened the supply lines I can hand pump fuel flow up too the spring loaded devices that are threaded into the top
of the injection pump... when they are loosened. Once these four spring loaded devices are again tightened down there is no fuel flow through or past them? ? ?
I am going to get a 12 volt fuel pump and attempt to use it to maintain 4 to 8 lbs of pressure to see if i can get fuel to the injectors. There is no electrical
power to the components of the engine at all. I am not trying to use or be concerned with the glow plugs as I can not even get fuel to the injectors yet. All I know
about the glow plugs is that they worked last time I needed them. Other than that they should be a non issue at this point. Everything is mechanical . The battery is near new and I have a battery charger hooked up to it when I am cranking the engine.
I will have to digest your last paragraph in that I have no electrical connections to the IP and will study how the lack of oil pressure would have any effect on the
ability of the IP to pump fuel to the injectors. I do have a mechanical oil gauge that shows me about 30 lbs while using the starter to get fire and smoke This engine is on a roll around cart on the floor. It have NO electrical connections or boxes attached to it at all, except for the starter. Everything is being done mechanically.......? ? ? Does anyone know the Tech name for what I am calling the four threaded spring loaded devices that are threaded in to the top of the IP that the injector feed lines are connected to ???? Thanks Don, for your input.
Have fun,
buckshot
I may have miscommunicated about the injector lines. I wasn't thinking about where the lines are fastened to the IP. Instead I was thinking about where the injector lines attach to the injectors, just before where the injectors thread into the head.
There is a mechanical fuel pump on the lower part of the IP. If it is working properly it will supply all the fuel needed to the IP. An electrical fuel pump might help with initial bleeding of the fuel system, but the only experience I have with that is on a 90's era GM diesel where they are stock and supply all the fuel all the time to the IP.
After spending some time thinking about it I might inadvertently have given you wrong information about the injection pump controller. There is no electrical connection directly on the IP. On the side of the block, under the IP, is a device that looks like a windshield wiper motor. It is a motor and gearbox with a shaft and arm that comes out of the gearbox. From this shaft/arm is a rod that connects to a control lever on the side of the IP.
This motor is wired into an electrical box that is mounted onto the inner fender of the pickup. This electrical box is connected to the ignition switch and the oil pressure sender. When the ignition switch is turned and held to the start position of the switch, the IP control motor runs/turns and moves the IP control lever to the start position. As soon as the motor fires the ignition switch is released and the ignition switch automatically returns to the run position. When this happens the IP control motor automatically moves the IP control lever to the run position because of the position of the ignition switch.
If you don't have the electrical control box, as I didn't, the position of the control lever on the side of the IP is very important. Spend some time getting to fully know the operation of this control lever.
Like the ignition switch start position, the start position of the IP control lever is spring loaded to automatically return it to the run position. Turn this IP control lever as far as it will rotate clockwise to the right. This will be the start position. When you let go of the IP control lever it will automatically rotate a little ways counterclockwise to the run position, just like the ignition switch (spring loaded). Now, from the run position of the IP control lever manually rotate the lever counterclockwise until it stops. This is the stop position of the IP, and this lever will stay in this position until physically moved. In this position no fuel can flow through the IP.
So, in a counterclockwise move from the start position you will have START, then counterclockwise move to RUN (spring loaded move), then move to STOP, which will be as far counterclockwise as the lever arm will move.
I hope this makes more sense to you and will help you get the motor started without the electrical control box. Without the electrical control box the oil pressure switch will have no function other than making the gauge read what the oil pressure is.
Oh by the way, when I tried to start my motor it was setting on a concrete floor (supported so it wouldn't lay over), and hooked up to a battery using a jumper cable. This proved to be an inadequate electrical hook up. I ended up using my pickup (running a CS 144 alternator) and two sets of jumpers, one to each battery in my pickup. I came to the conclusion that a single jumper cable wasn't allowing enough juice through to turn the starter over fast enough. Two jumper cables, one to each battery on my pickup was enough to turn the starter over fast enough. The jumper cables were not as big of gauge as the stock battery cable.
