SD-22 Diesel engine Portland CL
charmalu
Post by charmalu »
I haven`t been on the forum in quite a while. 82 Datsun is sitting in the shop with #2 Cylinder kaputz, lost it back in 7/14 @ 483K miles. Dang cheap Jap junk LOL. JK been a good truck.
It`s in line with the Mercedes Diesel and Ford 6.9 Diesel projects...get to em eventually.
I came across this SD-22 in the Portland, Or. area CL. Don`t see many of these anymore.
https://portland.craigslist.org/wsc/pts ... 76872.html
Running sd22 with a 5 speed manual trans. The motor came out of a 1983 Nissan 720 sd22 engine, and has one good trans but need to be assembled with the rebuild kit that I have included, I also got a new clutch for it, and a extra transmission as a spare or parts. The radiator is included too. Custom made stand alone wire harness kit is there too. I have the slip yoke and flange to make driveline.
I changed plans and converted my truck into something much larger, and got a much bigger engine for my project so this would be an excellent little swap over if you seek torque or fuel mileage. I was getting 30mpg on this setup on a 4000lb truck
I'm firm on $700
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
truewind
Re: SD-22 Diesel engine Portland CL
Post by truewind »
Did you sell this engine?
Are you looking for an engine truewind?
Where are you located?
