LD28 crankshaft help
broomeld
Post by broomeld »
Hello,
I am new to the forum and seek some help.
I am trying to source the part that attaches the the crank shaft and drives the injector pump belt.
I removed this to repair some stripped threads that secure the pulley, however upon re installation the crankshaft key must had moved, this has resulted in the key breaking the part exactly where the main crankshaft seal runs.
Being in the UK the LD engines are pretty much non existant, does anyone have any donor engines which i could purchase this item?
Regards
