Flywheel Tooth Count SD22
djekk
Post by djekk »
Anyone know what the flywheel tooth count is on a SD22 5 speed in an 82 truck?
This info would save me the work of pulling it apart to count them.
Apparently, ninety-nine.
http://www.ringgear.co.nz/Our_Products.shtml#NISSAN
120 for the LD28 (and a whole pile of other common Nissan engines).
NAPA sells the SD22 flywheel (through 10/82, it says), for $73, their part No. "SDF 309", with a $37 core charge. However, you can't look it up via napaonline.com for some reason. I see it in the NAPA ProLink system, but not on the retail system -- the retail system doesn't list the diesel engine in the drivetrain category. Weird.
