Crawl Space excavation via vacuum
Posted: Wed Sep 25, 2024 6:59 am
Crawlspace excavation (removing dirt) from the crawlspace of a 1950 home with existing crawlspace clearance of 9" (dirt to joists' bottoms). The plan is to use "shop vacs" to provide the soil transport and cyclonic separators to separate solids from the transport medium (air).
Idea from a YT vid.
Kevin used a couple of the larger cyclonic separators in series, 3" manifolding, and three generic shop-vac style powerheads in a neighbor-friendly enclosure:
My current plan:
Dirt is collected in drums that are situated on a dumping truck. Drums are open on the bottom and restrained by straps near their tops. When the bed is raised, the drums should rotate close to parallel with the truck's bed, allowing the dirt to empty from the drums, but the drums remain strapped from the front of the bed. After lowering the bed, the drums can be placed upright again. I have enough room for around (24) drums, and I have that many stored for use.
The cyclonic separators are attached to drum lids, which can be moved to empty drum(s) as the drums fill.
The primary separator is steel and larger than the secondary separators. Almost all of the dirt will separate into its drum, and that drum will have an ultrasonic level sensor, installed in the lid, to warn when it's near full. Normally, it lights a red strobe; depending upon how reliable this sensor is, it might be used to turn off the vacuums.
Major parts
Steel Super Dust Deputy 5" Cyclone
https://www.oneida-air.com/dust-deputy/ ... -separator
Dust Deputy 2.5 DIY Cyclone Separator
https://www.oneida-air.com/anti-static- ... -separator
RIDGID 16 Gal. NXT Wet Dry Vacuum
https://www.homedepot.com/p/RIDGID-16-G ... /304795088
Infrared Dust Sentry Bin Fill Level Indicator
https://www.oneida-air.com/dust-deputy/ ... -indicator
Standard Duct Reducers
(5x3, 6x3)
https://www.oneida-air.com/steel-dust-c ... r-fittings
Suction Hose, 3" Gloxo (stiff)
3x20
https://www.amazon.com/Gloxco-Suction-T ... B0989BKCQ3
Suction Hose, 3" Powertec (more flexible)
https://www.homedepot.com/p/POWERTEC-3- ... /308005488
https://www.amazon.com/dp/B06XKQML35
3x10
Elbow, 3" 90°
https://www.homedepot.com/p/Cantex-3-in ... /202043225
Duct Quick-Change "machine adapter", 3"
https://www.oneida-air.com/3-inch-machi ... clamp-duct
Duct Quick-Change Clamp, 3"
https://www.oneida-air.com/ductwork/qui ... ocking-pin
Duct Quick-Change Elbow, 90°
https://www.oneida-air.com/ductwork/qui ... t-fittings
Duct Pipe, 3" x 10' ABS DWV
https://www.homedepot.com/p/IPEX-3-in-x ... /309282460
Duct Street Elbow 90° 2.25"
https://www.oneida-air.com/flex-hose/ad ... hose-elbow
Drum Lids, 55G (for drum bottoms)
https://seattlebarrel.com/
$10 ea. for "reconditioned" lids w/gasket.
View of drum restraint system, and one of the secondary separators installed:
Spare drums awaiting their bottoms removed:
Idea from a YT vid.
My current plan:
Major parts
(5x3, 6x3)
3x20
3x10
Elbow, 3" 90°
