Some moderators may want a walk-through on how to delete a forum spammer, and all their posts along with them. What follows are few screenshots.
PLEASE DON'T DELETE NON-SPAMMER USERS
You can only "Administer User" if you have Moderator privileges or similar.
Find a post by the spammer, and select their username ("rlaggren" in the example below):
If you have sufficient authority on this forum, the next page will show "Administer User". Select that option:
You may or may not have to log in again. Same credentials as you normally use.
Scroll to the bottom of the next screen, use the drop-down box to select "Delete posts", the select "Submit":
The following screen will be a confirmation, warning that this can't be un-done. Select "Yes", and you're done: the spammer's account and all of their posts have been removed.
How to delete a spammer (and all their posts)
Moderator: Nissan_Ranger
Re: How to delete a spammer (and all their posts)
This is the same as I do at the other place.
