Portland CL: '81 720 KC w/SD22 down to $425
redmondjp
Post by redmondjp »
http://portland.craigslist.org/mlt/car/273885887.html
1981 Datsun / Nissan Diesel 720 King Cab Pickup Truck. - $500
Reply to: sale-273885887@craigslist.org
Date: 2007-02-05, 1:16PM PST
This truck is very, very ugly. The bed is totally rusty, and the body is rusted and covered with moss. The diesel engine is really where it's at.
Nissan imported only a few years of these trucks with the famous SD22 4cyl Diesel Engine with a Bosch licensed "Diesel Kiki" inline injection pump. I bought this truck for $300, got it running again, then moved it from the sticks into portland. Parked in my driveway now, I have rebuilt the injectors at a cost of $150(have documentation) and reinstalled them. I thought that this would solve an early ignition problem that was showing up as pinging, knocking, and excessive smoking, however the problem has only gotten worse with the richer mix of fuel coming from the new rebuilt injectors. Not wanting to look deeper into the problem or spend more money on the issues. I no longer plan on using the SD22 Motor out of this truck.
$500 obo
503-214-2244
This item has been posted by-owner.
[no pictures posted]
moose60
Post by moose60 »
Sounds like our member, The486's truck.
Byron
82 Datsun 720 KC SD22
MPG Machine
Running the phone number through Google gets a WVO/biodiesel consulting service:
http://portland.craigslist.org/mlt/aos/273250768.html
and a couple other hits.
ocd
Post by ocd »
his email is k@spaz.org just like his website on profile
-Noah
82 datsun 720 KC w/sd22
redmondjp
Still for sale, now $425
Post by redmondjp »
http://portland.craigslist.org/mlt/car/298121577.html
1981 Datsun / Nissan Diesel 720 King Cab Pickup Truck. - $425
Reply to: sale-298121577@craigslist.org
Date: 2007-03-21, 4:20PM PDT
1982 Datsun / Nissan Diesel 720 King Cab Pickup Truck
I will assume that if you are looking at this, you know what you are looking for...
some info:
The bed is totally rusty, and has carpet glued into it (used to have a camper shell)
The body is rusted and covered with moss.
The heater, Lights, Brakes, Clutch, Transmission, Radio all work!
The engine is the Famed Nissan SD-22 4cyl Diesel!
read on...
Nissan imported only a few years of these trucks with the famous SD22 4cyl Diesel Engine featuring a very awesome Bosch licensed "Diesel Kiki" inline injection pump.
I have been driving this truck all over Portland. It has 5 gears, and will go freeway speeds. Still getting over 30mpg!
problems:
The truck has low compression. I have not done an accurate compression test, so I don't know on what cylinder(s) or how badly. Could just be as simple as a valve issue? or Piston Rings/Sleeves.
I'm guessing it's a ring/piston problem, because there is some blow-by and it burns a quart of oil every 200 miles.
The truck will start if you Plug it in for 15 minutes when cold (it has an AC block heater/coolant pump)
The truck smokes quite a bit at cold startup, but then runs smooth afterwards.
The Watter Pump Bearing is going out.. needs to be replaced. Makes a nasty noise when you start it up, but quiets after it's warm. No coolant is leaking.... yet!
The engine lacks power, and smokes ALOT under heavy acceleration.
Basically the engine needs an overhaul.
However.. It is drivable, you won't go fast.. and you might leave a puff of black smoke when you take off from a stop light if you don't baby the accelerator.
some work has been done:
New Injectors! ($240)
Bad fuel removed from tank,
Tank pressure washed
Several tanks full of fresh diesel have been ran through the system all the algae seems to be gone.
New fuel filters.
New Battery.
New Clutch Master & Slave Cylinders, New Hydraulic lines.
Good spare tire and 4 OK to drive tires mounted on truck.
Motor alone is worth the asking. Trans is good, body has life left in it.
Could be an ideal Biofuel truck for around town! Or do as I was planning and rebuild the SD-22 and dump it in a Nissan 4x4!!! Off-Road @ 30+ mpg!
no tags.
price dropped $425 obo / trade for straight 6 van, step van, camper, 50cc or larger scooter/moped
email or call 503-214-2244 lv msg.
redmondjp
Still for sale, $555/425, good price for a drivetrain donor
Post by redmondjp »
http://portland.craigslist.org/wsc/car/360141549.html
Reply to: sale-360141549@craigslist.org
Date: 2007-06-25, 2:40PM PDT
1982 Datsun / Nissan Diesel powered 720 King Cab Pickup Truck
some info:
5-speed, 75mph on highway, 30+ mpg!
Truck is very rusty.
Bed has rusted through in spots, tailgate still working great!
The heater, Lights, Brakes, Clutch, Transmission, all work great!
Smokes when cold, and under hard acceleration.
read on...
I have been driving this truck all over the place! I love it, but I'm giving it up for my mercedes diesel.
New Glow Plugs ($40)
New fuel filters.
New Battery.
Could be an ideal Biofuel truck for around town! Or do as I was planning and rebuild the SD-22 turbo charge, and dump it in a Nissan 4x4!!! Off-Road @ 30+ mpg!
Truck has current tags good till 6/09
$555 obo
email only
That's a fair price. If I didn't already have one, I'd consider it.
harrisonm3
Trying to buy the nissan diesel
Post by harrisonm3 »
This guy is hard to get ahold of
I'm trying to buy the vehicle
He says that he is in NE Portland
But sent me emails saying he would be in Gaston Oregon an hour away
Does anyone else no anything about this guy?
Matt Harrison
86 KC 4x4 Looking for a Diesel power plant
83_maxima
Post by 83_maxima »
Sounds par for the course for Craigslist. I take the good with the bad (the flakes with the not-so-flaky) because there are deals everywhere you turn...
If he really wants to sell it, he will get in contact with you (at least in my experience).
I know exactly where Gaston is, and it's a long way from NE PDX. That stinks. Still, I'd drive to Gaston to look at it anyway, but I drive to Carlton/McMinnville fairly often.
Users browsing this forum: Semrush [Bot] and 2 guests
