LD28 vs TD27t
Kolatogari
LD28 vs TD27t
Post by Kolatogari »
OK, I'we been thinking this over N over again. I have 2 engines that I could put in my old Range Rover. one is an LD28(non turbo) out of other rangie, end a TD27t turbo out of Terrano2. The TD27t is lighter and has more power, but I always liked the old LD28, slow N stedy. what do you think?
windsock
Re: LD28 vs TD27t
Post by windsock »
Kolatogari wrote:OK, I'we been thinking this over N over again. I have 2 engines that I could put in my old Range Rover. one is an LD28(non turbo) out of other rangie, end a TD27t turbo out of Terrano2. The TD27t is lighter and has more power, but I always liked the old LD28, slow N stedy. what do you think?
Always get quizzed on why I put an LD28 into a land rover 110. Answer invariably starts with "I can fix it, if it breaks", followed by a phrase along the lines of "it hardly ever does", and ends with "I like the simplicity and steadiness of the engine".
I think you may have answered your own questin... "...but I always liked the old LD28".
Good luck with what ever way you go...
JasperG
Post by JasperG »
got an old LD28 going into a series rover project myself.... only issue I have is parts are very hard to come by...Gordo
Kolatogari
JasperG wrote:got an old LD28 going into a series rover project myself.... only issue I have is parts are very hard to come by...Gordo
Yeah, but they are plenty of old laurel Taxi's lying around.. so. En the dealer servise is ok.
I'll think I try the TD27, if I don't like it,. i can always put the LD28 in...
TurboKota
Post by TurboKota »
Kolatogari, really... I cant believe you would even consider the LD since it guzzles fuel like a big block Chevy and breaks crankshafts so often... :lol:
LOL... Sorry to the others here but this is sort of an inside joke between us. Like I said before I think you should go with the LD. The comments listed above were the reason I decided to give the LD a try on my re-power conversion project...
In case others would like to see what I was talking about it's here...
http://www.4btswaps.com/forum/showthread.php?t=12211
Users browsing this forum: Amazon [Bot] and 38 guests
