injection timing query
minimog
Post by minimog »
Hi all,
Just about to check/set the injection timing with the DTI clock in the back of the injection pump when I realised there is an anomoly in the FSM. My FSM is for an 810 Datsun fitted with the LD28 and it gives the measurement as 0.86mm +- 0.03mm. In Al's online FSM it gives the same measurement as 0.75mm +- 0.04mm. I'm going to opt for the dimension from Al's manual to start with. What would the difference in dimensions mean in real terms, more advanced pump timing with the higher figure?
Thanks, Dave.
From 1982 FSM, page MA-26:
Plunger lift mm (low altitudes)
M/T 0.85 +- 0.03
A/T 0.81 +- 0.03
(for high altitudes)
M/T 0.90 +- 0.03
A/T 0.85 +- 0.03
minimog
Post by minimog »
:shock: Now you're relly trying to confuse me :? Such a choice of plunger lift dimensions, I feel like a child in a sweetshop. (candystore)!!
Still, from those 4 choices, only one must apply. What is a DTI clock?
minimog
Post by minimog »
windsock
Post by windsock »
minimog wrote:Dial Test Indicator clock.
http://www.lasertools.co.uk/item.aspx?cat=687&item=549
Cheers for the link to that dial tool kit. Looks useful.
Keep us all updated on your timing solutions. Will be interested to know which setting you go with.
Phil
Does the engine run currently?
minimog
Post by minimog »
Hi all, well I got the pump timed in. I decided to go with .75mm setting that is given in Al's online FSM. Engine runs sweet as a nut with just a small puff of white smoke on cold start up, which could be explained by my glow plug timer only runs for 5 seconds? I was going to try some of the other settings but I couldn't be bothered to remove the injection pipes again :roll:
Thanks, Dave.
Video to follow when I get 5 minutes to upload it!
