LD20-II Timing Info
rhcp
LD20-II Timing Info
Post by rhcp »
Can anyone Help ME... I bought a Timing belt with NO timing Marks... Does someone KNow how to Time this Model? Or where can I buy a timing belt with the marks?
PLease HELP
factory belt has no marks.you count teeth.
how many teeth on the belt[2 types]
timing marks are on the cogs and behind on the oil pump case/tin cover.
rhcp
Post by rhcp »
141 teeth...
rhcp
Post by rhcp »
141 teeth...
rhcp
Post by rhcp »
Great post on the Diesel Doc..do u know if that is correct for 141 teeth?
I dont know.
i found that you couldnt get the cam possition wrong as valves hit the pistons..
im certian that the cam dowl or a mark on the cam lines up when you have the top cover off.
the cam timing gear marks are parrallel with the IP pump marks.
i used the tacho pulse chopper wheel to find TDC but after i found the timing mark on the front oil pump case.on water pump side.
Users browsing this forum: Google [Bot] and 31 guests
