auto q's---new question
nogrip
Post by nogrip »
is there a kickdown for the auto??
i have a feeling its vaccuum controlled via a little dooh dah on the IP????
my new motor is missing this part...so will the trans kickdown at all? or will it be a manual shift now with the shifter?
i figured out why the end of the crank was different, theres a spacer on the end of the crank that pops off...so thats all sorted now.
trans is now on the new motor and am gonna put the turbo and manifolds on today..
might even get it into the van today too...if i can manage to get the oil pressure line into the collet,its being a pig bear and wont go through..gggrrr
ld28t in a 81 transit van
IIRC the auto tranny has a mechanical link - downshifts when the accelerator is depressed ALL the way to the floor. There is probably also an RPM/gear interlock but don't remember ever looking into it.
HowlerMonkey
Post by HowlerMonkey »
3N71b and 4n71b use a switch on the gas pedal to actuate a solenoid.
nogrip
Post by nogrip »
oh cool...i was wondering what that switch was for :roll:
seeing as its a custom install i have no idea whats what in it..
shes all in,BUT i managed to snap a steel pipe off the bottom of the trans when i was manouvering in there...only noticed once it had fluid in it..
easy fix though...
should be fired up tonight
nogrip
Post by nogrip »
bloody thing wont fire up now...
the terminal at the pump has constant 12v,theres fuel getting to the injectors,it has a different wind over sound to this one...almost like theres no compression....
annoying to say the least
nogrip
Post by nogrip »
oh yeah and now theres a heap more atf pissing out from the other pipes under the trans...bloody thing is pissing me off
nogrip
Post by nogrip »
any suggestions??
the guy i got it from said it ran fine in the last car it came out of..
so its got fuel at the injectors
power at the ip switch thing
power at the glow plugs
and its winding over...
should start yeah??
so what now????
> what now...
Now you work out which of those things you listed that you think are there.... really are not. And you might also check the valve lash if you haven't yet (don't recall if you said you did that).
nogrip
Post by nogrip »
got it going this arvo..
just cranked it over for ages,then primed it,and repeated over and over agin over an hour or so.
almost started then died, so i repeated it, then it fired so i kept it turning over and it finally took...then it idled perfectly
sounds real good...
will offer it up for sale now though..
have too many things on the go to finish it..
ill keep it if i can sell some other toys instead though
ni.san
Post by ni.san »
nogrip wrote: then it fired so i kept it turning over and it finally took...then it idled perfectly
sounds real good...
Good to hear! What exactly are you looking to sell btw? :D
nogrip
Post by nogrip »
got offered $2000 last night.. without a wof/reg/ruc...so as is..
would be willing to put a wof etc on it for the right price
nogrip
Post by nogrip »
ok so i got the van running etc..
now the trans wont shift into top gear...
o/d light lights up when i push the button..
but it wont do anything if its not in top gear..
what could cause this to happen? it used to work fine..
