cover the flywheel
osvaldo garcia
cover the flywheel
Post by osvaldo garcia »
Hello friends.
I need to cover this opening to keep out water and earth, I bring some problems
Thanks, and :oops: :oops: my baaaaaad english :wink:
Looks like you have solved the problem. Good work.
HowlerMonkey
Post by HowlerMonkey »
If you are not happy with your current cover, almost every L engine (4 or 6 cylinder) that came with an automatic use the same cover.
The cover from a 280zx should work fine and it's possible that a nissan truck with L or naps-z engine with automatic cover would also work.
Users browsing this forum: Google [Bot] and 29 guests
