primer pump
powerstroke6.0
primer pump
hello to all,1st post. i have a new to me 81 datsun regular cab with the sd22. it has been sitting for about 10 years and my son and i are trying to get the old girl on the road again. i have drained all the old fuel out of the tank. replaced primary filter. backflushed clear plastic filter,replaced all rubber fuel lines. heres my problem i got the primer pump unscrewed but it will not come up so i can push it up and down to prime the pump. the knob will unscrew about 3/4 turn then gets tight again. thx ed
- Has thanked: 1 time
powerstroke6.0
powerstroke6.0
yes it was added later not on fire wall just inline, i fixed my primer pump it was stuck in the bore, i removed it from ip took it apart used alot of pb blaster on it, put it back together. bled pump,cracked all hp lines bled them. truck still would not start. cked gps no voltage going to plugs. but i could hear gp relay clicking about every 45 sec. or so. did a big no no shot just a verry small dose of either into intake and it cranked right off let it run for about 10-15 min. sounded real good no smoke at all, good throttle response, now just have to figure out gp issue. gona need water pump bearings was grawling. also gona need a clutch master and slave for it. and mabe a clutch kit reason for it being parked for the last 10 years. ok thx for all the help. gona do a search for gp circuit to see what i can find. thx again ed godbless all
