LD28m - Heat Exchanger - Need Input
Cayo Hueso
The heat exchanger core blew out. Tried to repair, but it is too far gone I'm afraid. Any idea where I can get a new one or an alternative exchanger that I can substitute for the Nissan?
Duaneclark
Re: LD28m - Heat Exchanger - Need Input
When you refer to heat exchanger, are you refering to the American term of the "radiator"? If so, usually if you can plumb in a similar sized unit from any other application and it should work.
Duane
Cayo Hueso
Thanks. Thays what I am understanding. So, im looking for one that will fit and ill be back in business.
- Been thanked: 6 times
Maybe take some measurements and have a look here
http://www.plumbnation.co.uk/radiators.php
There are a number of different sites that list radiators by size etc. May not be an OEM rad but might get you close enough.
Good luck
Good luck
Cayo Hueso
Turns out I got one fabricated from Seakamp in Bellingham WA. For about $700
