Item Specifics - Item Condition
Condition: Remanufactured
Condition: Used
This is a 1980 Nissan SD33T diesel engine. The short block was imported from Canada where it had been bored .20 over. It has new pistons, wrist pins, main and rod bearings. The injectors have been rebuilt as has the head. The head has been welded, milled and valves reground and new valve seals. The injection pump has been rebuilt and calibrated. The turbo has been rebuilt. It has a new water pump and new glow plugs and a rebuilt starter.
I am selling this because it will not fit in the vehicle I intended to put it in.
The SD33T was used in International Scouts and pickups. This is from a 1980 Scout. These engines are also used in forklifts.
eBay (MN): SD33T rebuilt long block
- Has thanked: 5 times
Auction 270142471956, ends Jul-22-07 07:00:00 PDT
