Help nissan 720 sd22 diesel
Has thanked: 9 times
Re: Help nissan 720 sd22 diesel
#61
There are lots of reasons to do that, one of the diesel components quit working and it would not shut the engine down anymore is one and that is an easy fix to not have to lift the hood and shut it down, or maybe it would not start because the arm would not move to the start position either, a low battery can cause the same issues that I just recently found out myself on my 720 diesel.
In the past I had people calling me about why their diesel would not shut down when they turned the key off, it was stuck in the run mode, I was always telling them to cycle the connection unplug and plug back in the injection pump controller plug, it appears they lose connection from dirt, corrosion, they would drive all the way to my house to have me cycle that plug and have everything work fine, I use spray electrical cleaner and blow it clean with compressed air myself.
Even that arm he removed can cause issues with starting and shutting the engine down if it is not adjusted properly.
Raptor6717
#62
Post by Raptor6717 »
OK, I'm learning. I discovered that the truck came factory with an sd25 diesel. The old man swapped the engine to an sd22 because the sd25 blew up. He rigged his own glow plug system, which wasn't working properly and added a manual shut off. The reason it wasn't starting was because the injection controller motor was never hooked back up and the pump was always in the run position. The problem is, I think he swapped the sd25 controller onto the sd22, and the rod is not long enough to reach it. That is why it was never put back on. (This is all my theory of what happened to the truck.)
So, am I missing something, like another piece at the end of the rod that connects to the injection pump controller? Or is it the sd25 controller and the sd22 rod is not long enough?
Another thing. It is now running rough again. I heard the rod knock noise that the man was talking about. It sounds like the injector is dumping fuel into the cylinder and it is blowing white smoke and missing.
It does start immediately now that I am giving it more fuel manually.
I opened the diaphragm housing and it has a tear in the outside part, but the truck still runs.
#63
Not too sure about the shut down lever and perhaps Wayne can offer some ideas. Mine had an electric shut down on the VE pump.
I would agree with your thoughts about a leaky injector(s). That "rod knock" that you hear is likely ignition pre detonation causing that sound.
Simply too much fuel and that cylinder(s) is firing too soon. Like having the timing advanced too much.
It may be time to remove injectors and have them rebuilt.
A bit spendy but I doubt that any "additive" ( Stanadyne, Power Service, Red Line etc) will work.
You could try them at double doses.
The introduction of the ULSD years ago contributed to this problem.
After rebuild, if you decide to go that route and rebuild them, one of the above mentioned additives might be a good idea per fill up.
I know on the VE pump I had it was pretty much a requirement. As previously mentioned they were a bit more sensitive to that kind of thing as they used the fuel to lubricate them rather than the engine oil like the inline pumps use.
Your injectors still require the fuel to lubricate them and the "old school" injectors were not built for the ULSD of today.
IF you decide to go that route and remove them there are a few gaskets you will need to source first.
If you search the forum you will find pictures of the ones you will need.
Digging the copper "tip" gaskets out of the head can be a bit of a challenge IIRC. I did not have the issue on my SD25 as they had a different style of tip gasket than the copper "crush" type.
The leaky injectors can also contribute to your "difficult" starting as well.
Removing the injectors is not a difficult job in itself, but, as previously stated, getting the tip gaskets out can apparently cause a swear jar to fill rapidly.
Raptor6717
#64
Raptor6717 wrote: 1 month ago OK, I'm learning. I discovered that the truck came factory with an sd25 diesel. The old man swapped the engine to an sd22 because the sd25 blew up. He rigged his own glow plug system, which wasn't working properly and added a manual shut off. The reason it wasn't starting was because the injection controller motor was never hooked back up and the pump was always in the run position. The problem is, I think he swapped the sd25 controller onto the sd22, and the rod is not long enough to reach it. That is why it was never put back on. (This is all my theory of what happened to the truck.)
Raptor6717
#65
Any thoughts wayno?
#66
A compromised diaphragm can be a big issue, the engine can try to run away(rev uncontrollably), this is not good, my 720 diesel truck did that once to me but I could not figure out why, it never has done that again since and that was years ago, maybe the throttle got stuck and has never did that again, I was standing on the brakes slowing it down and things got better.
As for the rods, I have seen/own rods that do not work as they appear to be too long or too short, one of the symptoms for me has been the engine will not shut off or it will not start, the arm on the injection pump is adjustable, but keep in mind that even the smallest adjustment can cause the same issues, it will not start or it will not shut down, I just went thru this issue, my fusible link was not making good contact, the battery was not charging properly and the battery got low, all of a sudden it would not start, I had to remove the arm to start the engine, this was new, by that time the battery had only a couple more starts before the starter would not turn the engine over, I charged it, but before that happened I had adjusted the injection pump arm so it would start, it would not shut off after that adjustment.
So, like I said I charged the battery, since that time I had to start dealing with it either not starting or not shutting down, I noticed my lower arm connection was kind of loose, it turned out the plastic bushing had worn out and half of it had worn thru, I had extra injection pump controllers so I got a plastic bushing from one of them and fixed that issue, I then started adjusting the arm(two screws and a slot), I adjusted them until I finally found the sweet spot, it starts fine and shuts down, but it shuts down slightly slower and it shakes the engine/truck a little, there is likely a spot where it shuts down smoother but it shuts down so I called it good.
OK, that said a fully charged battery is needed for things to work properly, it has to turn over fast enough to get the controller to move to the start/run position, it also has to shut down when the key is turned off, finding that spot can be frustrating, it had me talking to myself, the Phillips head screws are very small and almost worthless now, I need to find new screws.
I cannot say much about the knocking as I am not there to hear it, I had to change out the o-rings in my injection pump connections where the injection pump lines go from the injection pump to the injectors, at some point doing this some dirt appears to have gotten in the fittings on the top of the injection pump, in the lines going to the injectors, this caused a bad knock, while it was running I bled all the connections, to me it appeared the dirt had made it to the #4 injector, I kept opening and closing the fitting on the #4 injector and maybe it was the surging but the injector cleared and it quit knocking, then I could hear all sorts of other noise, I finally figured out and fixed all the noises and hoped this was the end of this ordeal, so far no more issues and my alternator is charging better than I have seen it charge in a long time.
OK, I am slightly worried about mentioning this, when I remove the rod to get the engine started because of issues I do not know of yet, when I re-install the arm back onto the injection pump arm, I have to move the injection pump arm towards the firewall(shut down position), if the arm is too short or long the injection pump controller will start squealing because it cannot move where it needs to move, this can ruin the injection pump controller, like I said the injection pump arm is adjustable, but if you loosen them screws you have to find the sweet spot which was a major pain to me, I likely spent a couple hours figuring that part out, either it would not start or not shut down, that had me talking to myself also.
I do not know how you are manually giving the engine more fuel, the only way I know of doing this is to hold the injection pump arm to the start position, that would take two people to do, one holding the arm to the start position while the other turns the key.
Raptor6717
#67
So do you recommend removing the injectors? When I give it more fuel, it ran horribly and missed and blew smoke. When it started it in the run position, it ran great.
I have another set of factory injectors
#68
Raptor6717 wrote: 1 month ago So do you recommend removing the injectors? When I give it more fuel, it ran horribly and missed and blew smoke. When it started it in the run position, it ran great.
By bleeding the injector lines while it was running I figured out my issue was the #4 cylinder, when I bled that one nothing in the idle changed, I got lucky and it cleared itself on its own, it might have been the surging of pressure when bleeding the line that cleared it, or it or I might have just got lucky, I will never know the answer to that one as it cleared at that time.
I do not like taking apart the injection system as it is hard to start sometimes, things get broke because they have not been moved in years/decades like the fuel return line system, that bracket breaks easy that returns the fuel to the fuel tank from the injector overflow that spans across all the injectors and returns fuel to the fuel filter canister.
If an injector plugged, it would likely be because dirt got into the system, maybe there is more dirt to plug up the new injector or other injectors, this is a problem, did you have the system apart at some point, I did when mine plugged up, somehow I got dirt into the injection line going from my injection pump to the #4 injector and it caused me great concern as it sounded like I was going to throw a rod.
Raptor6717
#69
All I did was open the injection lines to bleed them.
It does have a small tear in the injection pump diaphragm like i mentioned, not sure if I caused it or not. A. I. said it is my issue.
I have a video of it running.
It runs but it might just have one injector dribbling like plenzen said. It seems like an injector because the miss clears while in gear over 10 mph.
IMG_2917.MOV
(45.73 MiB) Downloaded 27 times
#70
I do not know everything about these engines, I just figure them out as needed to make the engine do what I want it to do, I listened to the video, it sounds like diesel, but my hearing is not great, I am supposed to get/fitted with hearing aids today, that smoke reminded me of one my 720 when it got overheated one night, unfortunately my dash lights quit working that night also and I had no idea it was overheating until I took an off ramp and seen steam coming out of the hood at the stop sign, it smoke bad after that night and I had to retire that engine, I was lucky to come across another SD25 engine soon after that to replace it, it is now a parts engine to me.
The diaphragm being ripped/torn is a concern, this would normally effect idle, raise it unknown amounts depending on condition of the diaphragm, the way it works is vacuum is created by the throttle body venturi, that pulls against a spring pulling the injection pump to the idle position because the diaphragm does not have a hole in it, if the venturi cannot pull the injection pump to the idle position it revs, if you do not push on the pedal it cannot get enough air to rev higher, this issue make the engine/driving uncontrollable to a point where the brakes are how you control it, it would/should smoke a lot, diaphragms are not readily available, when one finds them they buy while available, I have several diesel engines and I have a couple just in case I need one, I have 2 SD25 engines and one SD22 engine with a VE type pump on it right now, a ripped diaphragm should create consistent idle issues, and run away issues when I let off the pedal it continues revving until it runs out of air from one letting off the pedal and hitting the brakes.
Like I said before, I figured out which cylinder was the issue by bleeding the injection lines, #1 changed the rpms and created a miss, #2 changed the rpms and created a miss, #3 changed the rpms and created a miss, #4 the idle did not change as it was already missing, I opened and closed the injection line like when bleeding it and it cleared and run properly again, like I said, I got lucky, this is how I figured out which cylinder was the issue.
Have you checked your valve clearances on your engine, the valves have to close for the engine to run properly.
When you open the injection lines to bleed them it was running, correct???, the only time I ever open them lines is to bleed them when it is running, if it is not running you introduce air into the lines, when I prime the engine, I let the injector return lines pump the fuel back into the tank.
All the air has to be out of the system, out of the fuel filter and everything else, this is the reason I fill my fuel filter before installing it as that leaves less air to bleed out, for me a couple pumps and the air is out, then I bleed the line going to the front of the injection pump, the rest of the lines the air should bleed back towards the tank, I normally do not bleed all the lines, only the ones leading to the injection pump and injectors after running and is still missing.
I do not know everything, I am also learning as I go, this is how I figured out that the injection pump controller arm does not work right when the starter does not turn over full speed(has a full charge and not half dead), when half dead the arm does not move to the run position, I have several arms and noticed some are slightly different in length, I have no idea which arms are from SD22 and SD25, I am positive I have got arms mixed up, I am pretty sure my SD25 has a SD22 injection controller on it, but I do not remember when that controller fell apart when I was driving it, that was a long time ago, I do not recall which arm it had on it, I suspect I would use the arm that was on the controller I picked to replace the broken one.
#71
The white smoke at idle when cold is usually unburned fuel. ( too much)
I go back to the leaking injector(s) for that condition.
Cracking the fuel lines at the injectors really does not do much as the fuel system will purge any air at the injectors back the the fuel tank via the return lines fitted to the injectors. The old CAV type fuel systems (Perkins etc) required the injector bleed but the return line system looks after that. If there is constantly being air introduced at the injectors then the pump is getting air from someplace. I would look upstream from the pump for that.
The above being said.
I have no knowledge on how the DPC controller or the shut down lever activates, or the diaphragm or whatever the pixies do to work and operate all of that.
My experience with that inline pump was limited to the marine application that was simply two cables that came from the wheel house. One to the throttle lever on the side of the pump and one cable to the shut down lever. A simple push button on the instrument panel for the glow plugs that glowed an element on on the dashboard with a safety cover over it, but many used it as a cigarette lighter as well.
The old marine glow plugs were near impossible to burn out.
I agree with the valve set as well. Tight valves will affect starting,
.014 set HOT on both the E and I.
Be careful with the valve cover gasket as it my be a bit of a quest to find one. I ordered 2 from Nissan 10+ years ago and they had to come from Japan back then.
They went with the truck when I sold it along with the rubber grommets that fit in the valve cover.
You are going to get Black doing that job.
Also very much agree with crank over speed and a good strong battery. Crank over speed will greatly help with starting.
My D21 came fitted with 2 batteries. Perhaps the redesign and knowledge learned from the 720 series had something to do with that as well as the switch to the VE style pump. But that's a guess.
I believe if you search this forum you will find the theory and operation of the DPC controller and all the associated things with it.
I think that maybe it was Al or even Phillip (RIP) that did an extensive break down of how it worked and the things that were needed to be correct as well as adjustments, voltages, incantations etc.
My truck had none of that nonsense going on, but did have it's own book of nonsense to deal with.
Good luck
Raptor6717
#72
I think it's the injectors, when I gave it more fuel it ran horribly. When the gps were working properly, it was just getting enough fuel to start in the running position and run and it ran great.
I am going to try the cracking injector test 1 by 1. If the valves were out of speck, it probably wouldn't start in the run position. I don't think it's the valves. This engine was swapped in from something, it probably had low miles. The truck itself has 214k miles, but that motor can't have that, he never drove the truck with the sd22.
The battery has 800 ca and 1000 CCA, it cranks fine. I just swapped in an old factory Hitachi starter.
#73
I only used bleeding the injector lines at the injectors to see which cylinder was my issue, it cleared doing that, so I expect I got lucky the injector cleared that time, it likely would have cleared anyway, I had opened them up before that and it continued to run bad/knocked bad, like it was going to throw a rod when I raised the rpms, I was kind of upset at the time, things had not went according to the plan, that was the first time I messed with them fittings and I had another issue.
#74
Yes the ignition knock can be quite loud and disturbing to hear.
On a more positive note however a rod will knock all the time so at least there is that.
Using the injector nut to see what cylinder is a good idea, at least it will direct you to the problem child, wont fix it, but will let you know where it is.
Try dumping a double dose of either Stanadyne, Power Service, or Hot Shot diesel injector cleaner in the tank and running a tank or two with that stuff.
You might get lucky and it will do what it says it will do and free up whatever injector may be complaining.
It might save you from digging the injectors out. (a project)
Use one of them going forward.
Just a thought here and perhaps Wayne could elaborate. I wonder if you disconnected the shut down lever from the pump totally and moved the lever on the pump to the "full run" position if things might change? As stated I don't know exactly what is required from that "system" to operate but going "full run position in the shut down lever" may eliminate a partially closed situation cutting the fuel off????
Just a guess on my part.
Get it hot and set the valves as well. I would be surprised if they have ever been done. If they are too tight it will be hard to start as well.
I used the Stanadyne Lubricity formula because of the VE pump.
I also used the Power Service winter formula because I live in the Great White North.
Keep us up to date with your progress.
Raptor6717
#75
I tried the injector test. I can't definitely tell what cylinder is not firing. The idle seems to pick up after each one is reconnected. But I think it was #3 that it started knocking after I reconnected it. Not sure though. I think it may be just the diaphragm.
Users browsing this forum: Bing [Bot] and 34 guests
