any hints?
CN4-33 Damper Plate needed
crzhors
I'm looking for a Damper Plate for my CN4-33 adapting to the Borg Warner 71C trans, 9 1/2 dia.,4- 5/16 bolt holes,6 springs,26 spline.
any hints?
JD
any hints?
SD22 Marine=M4-33 1974Challenger 40
pbknowles
Since you have the marine version, the flywheel housing and drive plate conform to an SAE specification and should not be Nissan specific. If you look at this: http://www.marathonelectric.com/generat ... saedim.pdf
it looks like you have an SAE 7-1/2 housing. That broadens your search options since now all you need is an SAE 7-1/2 drive plate for a BW drive. This standard is common on industrial and marine applications so that any engine will bolt to any drive or pump or generator or whatever.
SD22 powered '85 Chevy S-10
crzhors
Damper Plate
Thank You PB, Its a good day when I learn something,like pieces of a puzzle, Maybe I can get the price of this plate down to earth, as soon as you say"marine" it becomes a $395 friggin specialty! Forklifts,Generators,Pumps... Back to the hunt!,
THNX, JD
THNX, JD
Users browsing this forum: Bing [Bot] and 14 guests
