From the text, sounds like one of our members.Reply to: sale-409958659@craigslist.org
Date: 2007-08-30, 11:34AM PDT
1982 Datsun / Nissan Diesel powered 720 King Cab Pickup Truck
info:
* The engine is the Famed Nissan SD-22 4cyl Diesel
* 5-speed, 70mph on highway, 30+ mpg!
* Truck is very rusty.
* Bed has rusted through in spots, tailgate still working great!
* The heater, Starter, Glow System, Alternator, Lights, Brakes, Clutch, Transmission, all work great!
* Smokes when cold, and under hard acceleration.
Nissan imported only a few years of these trucks with the famous SD22 4cyl Diesel Engine featuring a very awesome Bosch licensed "Diesel Kiki" inline injection pump.
some work has been done:
o New Injectors! ($240)
o New fuel filter.
o New Battery.
o New Clutch Master & Slave Cylinders, New Hydraulic lines.
o Good spare tire and 4 good tires mounted on truck.
Motor alone is worth the asking. Trans is good, body has life left in it.
Truck has current tags good till 6/09
$525 FIRM
Email only!
+ This item has been posted by-owner.
+ Location: NE
CL (OR): 1982 720 KC SD, $450
http://portland.craigslist.org/mlt/car/409958659.html
Re: CL (OR): 1982 720 KC SD, $525
Words "Famed" and "awesome" narrow it down WHO is the member.asavage wrote:-snip- From the text, sounds like one of our members.
Now down to $500:
http://portland.craigslist.org/mlt/car/433854765.html
1982 Datsun / Nissan Diesel powered 720 King Cab Pickup - $500
Reply to: sale-433854765@craigslist.org
Date: 2007-09-27, 1:31PM PDT
Info:
* 5-speed, top @ 70mph+ 25-30 mpg
* Truck Cab is very rusty, has some through rust, and some dents
* All windows, doors, locks are working
* The Heater, Starter, Glow Plug System, Alternator, Lights, Wipers, Brakes, Clutch, Transmission, all work great!
* Truck has 110v plug in block heater installed, works great for cold mornings
* Truck runs and drives good, but smokes and lacks power due to the following easy to fix issues:
o over fueling issue caused by missing nylon bushings on DPC fuel flow control linkage. Easy fix, if you can find nylon bushings?!
o oil consumption issue caused by worn valve stem seals. 8 seals are needed at a cost of less than $20, and about 2 hours to put them in.
I would be glad to help you do the work too.
Work that has been done:
o New valve cover gasket
o New fuel filters
o New Biodiesel Resistant fuel lines
o New battery
o New brake pads
o Recently aligned front end
Motor alone is worth the asking. 400+ PSI on all 4 cylinders. Trans is good, body has some life left in it.
Engine needs valve stem seals replaced valves adjusted and other minor adjustments, currently truck is good for around town or short trips only.
truck is running on b100!
Have title in hand, Truck has current tags good till 6/09, runs and drives
Please, only contact me if you know what your looking for and you want to DRIVE IT AWAY TODAY!
Price Lowered 9/26
$500, CASH, FIRM! WHAT A DEAL!
+ Location: NE
Down to $450:
http://portland.craigslist.org/mlt/car/440987566.html
Price Lowered AGAIN 10/02
$450, CASH, FIRM!
Users browsing this forum: Bing [Bot] and 6 guests
