pipe coming out of the sump
waiwurri
Post by waiwurri »
Hi, on the LD28 in my boat. On the right hand side of the sump looking from the front of the motor there is a pipe coming out of the sump. It only comes up a short distance and has been blanked off. Could anyone tell me what this would be for. I am sure its not an addition and is from the factory.
Greatful for any advise. Thanks Pete
minimog
Post by minimog »
Return to sump drain for the oil from the vac pump mounted on the rear of the alternator.
waiwurri
Post by waiwurri »
yes because the vac pump has been removed hence the blank off. I was worried it could be under pressure. Thank you for the information. Pete
