starting circuit
dieselfink
starting circuit
does anybody have the starting circuit wiring diag for a 83 maxi realy getting tired of jumping it at the starter....ginition switch is sending power in the start position@black/yellow wire then somewere it turns to black/red to starter ...ive checked the green relay which im assuming is the starter relay, it is good but getting no power @ coil side of relay..alldata has nothing that i have found on the starting circuit phhh..
83 maxi, ld28, fire ringed, copper head gasket, 5 angle valve job, ported head, coustom turbo flange, gt28r ball bearing turbo 20psi of boost@1250degrees, timing bumped, full load screwed, cold air, straight piped, 308k miles..for now
Most likely it's the corroded wire connection in the wire bundle running on top of the "frame" rail under the fuel filter. BTDT, it's been written up and pictured up here on the forum somewhere, you'll find it if you search.
Here is the thread:
Main wire harness break that prevents starting
http://nissandiesel.dyndns.org/viewtopi ... ght=solder
As a temp. workaround I have run a separate wire from the ignition switch to the relay.
Here is the thread:
dieselfink
Users browsing this forum: Amazon [Bot] and 28 guests
