My truck has been gradually declining, it will run for miles, then, especially when going up a hill, when I shift into a lower gear and increasing RPMs, start chugging. I replaced the fuel filter, bled the air from the lines, and thought I had it done. Then the test run, (about 3 miles) left the truck stranded at the side of the road. First thought was that I'd not completely bled the air from the fuel lines, but it seems it wouldn't have gone the 3 miles if there was air in the lines. I'm borrowing a neighbor's car to pick up an air filter this morning, (it's due for one of those too, but I had to order it, not a stock item... like the fuel filter also wasn't!) Any ideas of where to look next for why the truck will run, then choke up and quit? It really acts like it's not getting fuel.
I got the truck towed back to the yard, removed the old air filter, and found what may be another clue. Something I've not seen before, the inside (engine side) of the filter appears loaded with soot. I don't know what that might be a symptom of!
I've reposted this on the SD2x Diesel engines under the same subject line, but will update that one as I discover more and probe deeper
'81 720 Runs, then doesn't.
- Been thanked: 6 times
Re: '81 720 Runs, then doesn't.
and that is where i just answered it
Good luck
Good luck
