Feasibility of LD engine swaps, and transmission adapting
I am starting this thread as a gathering place for any info on the SAE bellhousing and clutch or any other means of mating the LD28 to anything other than a Nissan transmission. Parts to adapt a non-Nissan transmission to any of the gas inline six Nissan motors may be relevant also if such things exist.
Would the SAE bellhousing for the LD20 be the same? It seems like it would.
Is there any chance some of the SD series parts could be used?
I am interested in this because of half baked plans to either put an LD28 in another chassis, or use one to run a generator. I am aware that a generator needs a speed regulated engine to produce 60 HZ power, but that is an issue for another day.
This is about the extent of the info I have, feel free to expand on it.
Thanks
Re: SAE bellhousing and clutch for the LD28
goglio704 wrote:Would the SAE bellhousing for the LD20 be the same?
I don't know why it wouldn't.
I think not.
I am sorta halfway serious about turning the blown engine from the "Vashon Truck" into a two-cylinder SD11, since it isn't any good for anything else. I figure I can probably get 20+ HP from it @ 1800 and direct-couple to an four-pole genhead (ST series from India). 10Kw sustained should be available. It'll be a heavy 10Kw gennie, but I can't think of why it wouldn't work. Since the engine is a lost cause for PU use anyway, my big cost would be the genhead and governor. And time :(
For those just tuning in, we had a good generator discussion, including governors, in this thread.
Besides the FS5W71, there is the Borg Warner T5 from the 280ZX, I think.
Pascal
LD28 in Land Rover
Post by Pascal »
The Land Rover I have is a 1967 model 107 inch wheel base.
It got a LD28 built in when I bought it in Jan 07.
Apperently this was a common replacement for the not so good original engine (I don't know what engine was originally in my Land Rover petrol 4 or 6 cyl or 4 cyl diesel, I was told 6cyl petrol, but I am not sure).
There is an adapterplate between the LD28 and the Land Roover 4-speed gearbox (1st and 2nd not synchronised! and 4th is 1:1). From the gearbox it goes to the transferbox (4x4) to the differentials, which I am going to change from 1:4.7 to 1:3.5 to keep revs down (much more torque with the LD28 than with any original LR engine) or to go faster (around 120Km/h).
The LR hasn't got heating inside (that was an option), I might build in a heater also. (Even second windscreen wiper and blinkers were an option!)
The LD28 hasn't got EGR.
Basicly bought it cheap without a propperly working engine: making a high pitch noise and the cooling circuit was leaking, no oil in water and no water in oil, half of the GP gone ... But there is hope... (but that is not for this tread).
Pascal
LD28 in Land Rover
Post by Pascal »
The Land Rover I have is a 1967 model 107 inch wheel base (bodywork and chassis in good shape).
Apparently this was a common replacement for the not so good original engine (I don't know what engine was originally in my Land Rover petrol 4 or 6 cyl or 4 cyl diesel, I was told 6cyl petrol, but I am not sure).
There is an adapter plate between the LD28 and the Land Rover 4-speed gearbox (1st and 2nd not synchronised! and 4th is 1:1). I think it is to match the Bellhousing to the gearbox at the clutch. From the gearbox it goes to the transferbox (4x4) to the differentials, which I am going to change from 1:4.7 to 1:3.5 to keep revs down (much more torque with the LD28 than with any original LR engine) or to go faster (around 120Km/h).
Basically bought it cheap without a properly working engine: making a high pitch noise after a few minutes and the cooling circuit was leaking and half empty, but no oil in water and no water in oil, half of the glow plugs gone ... But there is hope... (but that is not for this tread).
I used to have a LD28<->LR adapter source bookmarked, but I spent considerable time a couple nights ago trying to find it and failed.
Was it this one?
http://www.tiico.com/roveradapters.htm
AN02L30 Nissan LD2.8 – Landrover 4 cylinder adaptor $395.00
AN02L31 Nissan LD2.8 – Landrover 6 cylinder adaptor $395.00
AN02L32 Nissan LD2.8 – Landrover R6 adaptor $395.00
AN02L33 Nissan LD2.8 – Landrover LT85 / Range Rover $395.00
FN02L30 Nissan LD2.8 – Landrover flywheel $490.00
No, but that's a good one too.
I've retitled this and am bumping it in case somebody missed it and has something to add. I've got a running LD28 in a very rusty Maxima. It needs a different vehicle to live in. :D
asavage wrote:Besides the FS5W71, there is the Borg Warner T5 from the 280ZX, I think.
I thought the T5 was just a sports car trans, but some research shows I was wrong. The T5 was used in a variety of brands and vehicle types. The combination of a T5 with an engine compartment that can handle an inline 6 might be the answer to an LD28 transplant. The Jeep CJ looks like such a creature. Some would rule out a naturally aspirated LD28 as underpowered for a Jeep, but I think it could work.
goglio704 wrote:Some would rule out a naturally aspirated LD28 as underpowered for a Jeep . . . .
Jeep Cherokee was offered with a Renault turbo Four for a number of years, and it's heavier than a CJ.
I agree, with a 5 speed and correct gearing, I think it would be fine until tire size got out of hand. I ran across one reference that indicated the front half of the Nissan T5 had an odd shaft length and spline configuation, the author was viewing it from the perspective of swapping a SBC into a Zcar. Since I want to attach to an L series engine anyway, the front half of the trans is less important to me than the back half. Unless somebody out there has done this and speaks up, I'll never know until I find the various parts and try it. Man, I hope somebody speaks up. :wink:
Does the CJ need to be 4WD? If so, you may have to hybrid the 280ZX Turbo input shaft into the CJ's T5 case (just guessing). Which might be a bolt-in operation. I am not at all familiar with the T5.
I don't guess it would have to be 4wd. I hadn't really ever thought of a 2wd CJ.
Further research shows the T5 trans is also used in the Jeep Cherokee up to the 1996 model year.
Users browsing this forum: Google [Bot] and 39 guests
