Al: When I had my injectors rebuilt recently, the rebuilder (authorized Bosch/Zexel/Stanadyne/Rotomaster rebuilder) went into some detail and showed me a Zexel advisory about the new ULSD as it would affect various systems. The recommendation was that UNTIL such time as field feedback confirms 15ppm fuel as delivered had adequate lubricity in any system, that a lubricity additive be used in high speed diesels. Seems Zexel is of the mind that 15ppm is suitable for the coming generation fuel systems only.asavage wrote:Yup. Point No. 6, post 168. For our part of the world, as in others, biodiesel will likely be the lubricity additive of choice. It's even price-competitive for a change.
However, refiners, distributors, and blenders are going to meet the ASTM std for lubricity in their own ways, depending on local and market conditions, so how any particular tankful of fuel meets the minimum lubricity is unknown.
As to consumers adding their own additives at the tank -- then, as now, it won't be necessary. Esp. in our low-pressure IPs, the tolerances aren't so tight that our IPs will "see" a difference. SNIP
As I messaged you privately, mixing 2% biodiesel (one gallon of B99 costing $5.60 at the moment) treats 50 gallons of D2. A quart of PowerService costing $5.50 treats 50 gallons at the stronger mixing recommendation. PowerService is available at every Wal*Mart.asavage wrote:While I don't doubt that diesel injection component mfgrs & rebuilders are touting additives -- they always have -- but when the US went LSD in about 1990, the lesson was learned in the US, and ULSD is a lot steeper decline in sulfur. I trust (really, I do) that the supply chain is now informed about the lubricity issue in a way that they weren't sixteen years ago.
And, since I always run some blend of BD, it's a non-issue for meNow, if I could just get rid of all these danged leaks . . . .
Earlier in the week, I discovered and bought this STP product. It's no different than any other diesel lubricity restorer but for ... the absence of any claim to increase cetane. Says 32oz treats 150 gallons. That works out to 1oz per 4.6 gallons. $8.asavage wrote:While I don't doubt that diesel injection component mfgrs & rebuilders are touting additives -- they always have -- but when the US went LSD in about 1990, the lesson was learned in the US, and ULSD is a lot steeper decline in sulfur. SNIP
Ok, the passage is:Zoltan wrote:Hopefully diesel fuel makers will have the brains to blend in lubricants into the new ULSP. Meanwhile, if you mix in as low as 2% biodiesel, you're "lubed". See
http://www.biodiesel.com/why_biodiesel.htm
Off Road diesel is:fud2468 wrote:What is off road diesel?
Ray Mac.
I think you meant "road tax". I think that the fuel's selling price includes one or more taxes, but that the road tax isn't one of them. But I could be wrong.philip wrote:1) a diesel motor fuel that has not been taxed.
Depends. Stationary equipment qualifies for a refund of all taxes paid as does heavy off-road only equipment. The tax exemption varies by state.asavage wrote:I think you meant "road tax". I think that the fuel's selling price includes one or more taxes, but that the road tax isn't one of them. But I could be wrong.philip wrote:1) a diesel motor fuel that has not been taxed.
