I ran across (on sale) one of those washable filters for a cheap price. With a filter, a 2-1/2" ID, 90 degree coupler from an off-road shop, a 3" section of 2-1/2" exhaust pipe, and three clamps, here's The Fix.
It COULD be ... but it is not. This filter is not cotton gauze rather, a cellulose-like material that still has to be washed and oiled like a K&N.kassim503 wrote:is it one of those k&n filters?
Plus you get that cool roar/drone when you step on the throttle -- and the SD22 does have a throttle (for those reading who didn't know).philip wrote:I COULD be ... but it is not. This filter is not cotton gauze rather, a cellulose-like material that still has to be oiled like a K&N
Well Al, it's a TOUGH call. Should I buy the neon treatment or spend the money on a chassis dyno test? Wonder if they would even need chock the front wheels.asavage wrote:
I tell ya Philip, you ought to get some undercarriage neon for that thing
Actually, I would not.asavage wrote:So . . . would you call your mod the "hot air intake kit"?
[g,d&r!]
Well.... rock and a hard spot. As shown, there was a big open crack in the OEM rubber that allowed (twice noted evidence) dirt to show up on the throttle plate VS. the arrangement shown which has prevented any recurrance of throttle plate dirt. BTW, there is no audible intake "honk" until the engine is well past maximum torque RPM and at full throttle.asavage wrote:I'm sure that the airflow around those headlights is HUGE.
As you know from our previous conversations, I'm not a fan of these oiled-element filters. Their use will void several OEM mfgrs warranties, and for the "cone" style elements -- like yours -- the average intake air temp goes UP, not down for the "cold air kits". Kids are buying these things for the style, not the performance. The opened-up air intake makes more noise, and they hear that and think that it must be making more power.
By "complete burn" do you mean best power or best emissions? When compensated, warmer intake air makes for lower emissions.Carimbo wrote:I thought that for a NA diesel, warmer intake air actually helps achieve a more complete burn?
ocd wrote:i did the same thing to my '82 720 w/sd22, minus the exhaust pipe corner, and it seems like the engine has lost some torque.
I don't know how or where you could draw that conclusion. For power, cooler air means more power PROVIDED ... the Fuel Control Lever position is optimized for that cooler air. Otherwise, when the Fuel Control Lever position is optimized for 120 degree intake air but ... now the ambient air becomes considerably lower, the colder, denser air has the effect of leaning the air/fuel ratio. In this uncompensated diesel whose fuel delivery was optimised for 120 degree intake air, this colder, denser air simply lowers engine output. On the other hand, fuel economy is best with hotter intake air provided the fuel control lever positon is optimized for hotter air. See thread Smoke Setscrewocd wrote: From previous posts it sounds like air temp doesn't effect hp/torque so now i'm not sure the the proximity to the engine would be the cause.
Drastic?ocd wrote: My first thought was that because of the drastic increase in air available the fuel air mixture was wrong and since there is no MAF no way for the engine to adjust itself -but i really don't know much.
Any thoughts?
thanks
where would i find this and how is it's position optimized?when the Fuel Control Lever position is optimized
i didn't realize this engine breathed like that. i did notice the puny exhaust pipe and was looking into changing the exhaust system for somthing that breathed better. what are the pros and cons of changing the muffler to a high flow system?Except for times of heavy throttle application, the air throttle itself flows less air than either air filter.
