Small overheating problem
The fans are in, almost all is well.
Except for one little thing, the temp gauge is at 5/8th up instead of its usual 3/8-1/2 position, after replacing the head gasket I feel this is way too hot for the engine and this is no good.
Before this I ran the engine with no fan and t stat for a system that usually runs at 120F and will work its way up to 180 once I hit a light. Now im running that twin electric fan with the thermostat on, could air be trapped in the T stat that cant get thru the little weep hole on the thermostat?
I think there was probably some kind of air bubble in the system because the upper rad connector is lower than the engine coolant outlet, but I think the water pump should be able to "blow" the air out into the radiator and out the caps. But I drove the car for a good amount of time and I didnt have a problem with massive overheating, it was stuck on 5/8th. Anybody got any suggestions? I dont want to open up the cooling system and do any kind of flush or have lots of coolant drop out of the car, im running that royal purple "water wetter" product, and its surely not cheap.
Found the running hot problem, I just forgot that my water temp gauge has been messed with and dosent take "correct" readings, it always reads hotter than it actually is.
With these electric fans I find that I do run hot when stopped, but only a little bit and was nothing like before. I wouldnt care that much but today was a cool day, 65 degrees, A/C belt snapped right now so I dont know what itll be like when the a/c kicks in, but its obiously going to run hotter.
Should I put a set of pushers on there too? I have one pusher, im looking to add 2 more (gotta use the small fans because of the bumper being in the way of everything).
Also I will set up a shroud in the near future, I have a 3/4 inch gap that is between the rad and the a/c stuff, either I run a shroud or move the rad back the 3/4 of an inch, and possibly run a bigger fan.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0034094154
Dont these fans look good enough to cool the car? Mabye its the 5 rows that are not touching the fan, mabye ill move the fan up, dosent heat rise so the hotter coolant will be up top? Its a crossflow radiator.
see drawing below
see drawing below
I was checking on electric fans the other day because I would like to get rid of the WP fan on the Dodge B250. I went to the Hayden website and they have an estimator for fan sizing for particular vehicles. I don't know if I agree with what they come up with for certain models but it does give you a general idea I think.
Good luck
sa
Good luck
sa
Well, I find that the fans cut it, but not by alot. I butchered up my dashboard more and installed a water temp gauge, the kinds with the numbers for the degrees so ill get really accurate readings, at operating temp the car reads 178F and after idling it reads about 185, a/c on a mildly cold day brings it up to 187ish, obiously nothing serious but the fans dont hold the temp very good if I do burnouts followed by low speed crusing. Even though burnouts are not part of my normal routine and probably happen about once every 2 months (get it out of my system), it shows that the fans are not able to keep with up with "extreme service," which includes trailer pulling uphill at 5 mph, ??pulling trees??, those types of things.
Do pushers help? The fan is rated for 351 CI/ 350 hp, so it HAS to keep up with my monster 2.4L, but idk why its not. Could it be the water pump? It is the better B/A pump with the stock design, im thinking of a possible flow issue at low speed.
Someday I gotta put some weight on the car on a hot day, blast the a/c and beat on it to make sure the system is bulletproof, I cant live with anything less.
Ben I got your ecu on the way- I PM'ed the tracking number
Did I post any pics of the fan? Ill throw some in someday, so what if it dont work, it looks so damn cool! Also the power gain was so much more than I ever thought possible.
Do you happen to know if the Ark of the Covenant or the Holy Grail are on display somewhere?kassim503 wrote:
Decided on resurrecting this old thread cause its a good thread for my ongoing coolant problems, good news is its not a fan clutch or head gasket related problem.
I was just kinda wondering how much the exhaust from the manifold can heat up the coolant? The first cyl's exhaust is about 1/8" away from the t-stat housing, and I have a exhaust leak there to blow more hot air on there.
Shes been running hotter than normal and the exhaust leak got much louder, so thats the reasoning behind my thinking.
Also, does anybody run a 170 degree t-stat? I am more comfortable with running the car around 170-180 instead of 180-195 that its doing now.
Any opinions would be appreciated, and Merry Christmas!
- Has thanked: 3 times
An exhaust leak can dump a lot of heat. Whether or not this is raising the coolant temp is debatable though.
On coolant temp, I am in favour of hotter rather than cooler. The engine's internal tolerances are designed with thermal expansion in mind, and the parts fit as designed at the designed operating temperature. Definitely no cooler than 180°, for me.
Good point, I wasnt thinking about it that way, Ive been shy of running things hot after I blew the head gasket on this motor. I forgot about clearances, so I guess im happy keeping her at 180.asavage wrote: On coolant temp, I am in favour of hotter rather than cooler. The engine's internal tolerances are designed with thermal expansion in mind, and the parts fit as designed at the designed operating temperature. Definitely no cooler than 180°, for me.
The exhaust leak is actually heating up the coolant around the T-stat, the stock sender, which is at the bottom of the gauge is reading kinda hot- 3/4 up the scale, and the aftermarket water temp usually reads from 180-195, I think its just heating up the coolant around the senders to make it seem like its running hot.
Im gonna try putting some high temp rtv around the connection, hopefully id find a solution without turning a wrench. Today, im gonna try going to town with some permatex sensor safe high temp orange RTV. Hopefully id be able to find something that works, im sure I could, there really isnt alot of pressure in there.
Dude, fix the exhaust leak. You probably have another on cyl. # 6 too. It's easy enough to fix, you just have to get the manifold surfaced.
Ben Martin
That may be the Cowboy Way, but it's not the Kassim way. He'll have to pussyfoot around the fix for a few months, before doing the professional fix.83_maxima wrote:Dude, fix the exhaust leak.
Anybody who's read this entire thread knows that!
Yea- exactly! Its 11 pages of one broken head gasketasavage wrote:That may be the Cowboy Way, but it's not the Kassim way. He'll have to pussyfoot around the fix for a few months, before doing the professional fix.83_maxima wrote:Dude, fix the exhaust leak.
Id rather dick around for years and spend several times more money than fixing the problem the right way, only to do it the right way after trying every easy way out.
I had the exhaust leak for a while, and its only the #1 cyl that leaks, the #6 used to leak until I cranked the stud down, which did something- surprisingly. I just wanna put the sludge on to keep the hot air out, the noise level is still acceptable, and there is a surprisingly little amount of stink so its not even close to being on my radar, ive got bigger problems to dump my money into elsewhere in the car.
