Diesel tachometer
- ecomike
I just ordered a diesel Tiny Tach today for $65.00 online. I called and got an update and the old style is out of stock, while the new style is on back order. The new style eliminated the battery and the new style has a BACKLIGHT now! The new style will be $95.00 shortly, once they are back in stock, but right now you can still order the new style one for $65.00.
Mike
Mike
- dieseldorf
Diesel Tach for under $35.00
I have successfully connected a regular engine-speed tach to the EGR-controller (diesel). A small circuit is needed to do that.
More info in this post
theminotaur
Questions on Diesel Tachometer options-Claification
Hi Al and NissanDiesel Members
You seam like the guy who is best for answering my question. Unfortunetly I can't seam to find a seach box on the forum for specific tach Q and A.
Regarding the Tiny Tach, which one should I purchase for my 1983 Diesel Maxiam:
DTL-6 Tach meter for Diesel engines with 6mm size transducer
DTL-1/4 Tach meter for Diesel engines with 1/4" size transducer
Where do I install the transducer?
I also read that you can modify the EGR control unit so that a circuit w/wire to connect to a Tachometer. Unforntently I only have the one on my car, can I purchase one pre-made and send my orginal one back to you? I am unsure if the car will run without the EGR control unit missing.
When I have the modified EGR control unit, what sort of Tach do I connect it to?
How much is the modified EGR control unit?
Finally the alternator method seams a bit to complicated for me.
By the way which of these three methods is the best?
>->>I just read about the door locks not opening, and read the solution. This forum is the best. If there anything I can do such as being a moderator or promoting the forum just let me know. This forum is life saver, and will recommend it to anyone who owns a Nissan Diesel vehicle!!
Thanks,
P.S. I posting this message to the forum for other members who might wish to read it or make a comment.
Thanks,
Check out my Yahoo group: http://tech.groups.yahoo.com/group/E-Vehicles/
Re: Questions on Diesel Tachometer options-Claification
I believe that 6mm is the correct size for the LD28. Someone pop in and correct me if I'm wrong. I no longer have one handy to measure.theminotaur wrote:Questions on Diesel Tachometer options-Claification
Clamp it around any injector line, any place.Where do I install the transducer?
The car will run fine with the EGR control unit unplugged, and no damage will occur.I also read that you can modify the EGR control unit so that a circuit w/wire to connect to a Tachometer. Unforntently I only have the one on my car, can I purchase one pre-made and send my orginal one back to you? I am unsure if the car will run without the EGR control unit missing.
Any gasser tach that will accomodate a six-cylinder engine. eGauges.com or Summit or Jegs are decent online sources for gauges.When I have the modified EGR control unit, what sort of Tach do I connect it to?
In this post I mentioned the price I charge to do the mod. Others might do it cheaper.How much is the modified EGR control unit?
Note two things: the EGR Rev Sensor (see this post must be in working condition for the EGR controller to be able to furnish your tach a signal, and they do go bad. Use an ohmmeter on the two leads to that sensor and test to make sure you have around 1310 ohms before you go further, because if you don't, you're wasting your money using the EGR controller method to drive your tach.
Also, I can no longer test the tach function after modification, as I don't own a Maxima anymore and my friend who does lives a very long way away these days, so bear that in mind. I used to modify them and test them before shipping, but I can't do that anymore.
Email me if you want me to proceed.
Thanks,
I have had 2 tiny tachs, one of them was great, the other is just about worthless, and when I contacted the factory about it, they sent another piece(the part that connects to the injector line), and it changed nothing, I sent another message to them, but have not heard back from them since(3 years ago?).
It will only show the RPMs under acceleration, the moment I let off the pedal it goes to total hours and stays there till I hit the pedal again, sometimes it don't work at all till it warms up.
Am I missing something?
I sanded the shit out of all 4 injection lines and tried it on all 4, it made no difference, as I said, the first one worked great, oh and I have now used it on two types of injection pumps also, inline and VE.
Any help will be appreciated.
Well I just read this thread, I guess it is a bit dated, oh well.
That's a pretty weird symptom (only displays upon acceleration). Offhand, I'd be looking at making sure that pickup-to-gauge wire is not shorting to the firewall, and replace the pickup (but you've already replaced the pickup).
There's always the alternator mod for your SD/720. You might be able to use a late gasser cluster ('83-86) and the factory optional tachometer that way.
- ecomike
Re: Diesel tachometer
I finally completed the custom wiring on my franken-jeep Cherokee that including the wiring through the firewall for this really cool tiny tach!!!! I love it. Works great. Bought it about 9 years ago and halfway installed it then, and took 9 years to finish it LOL. Cleaned up some of the mess of obsolete wiring at the same time. Now I need to wire it to a dash power switch so it turns off.
asavage wrote:Most of the instrument cluster is different, between the gasser and diesel versions. One glaring lack is the tachometer -- diesels didn't get one.
One solution (that I have not tried) is a TinyTach.
Diesel Tiny-Tach™They're $65 (in 2005; $95 in 2013), and use a clamp-on piezoelectric pickup on an injector line.
- Engine RPM to 19,990.
- Correct reading regardless of the number of cylinders.
- Displays RPM when engine is running.
- Automatically displays run-time hours when engine is shut off (and power is still on).
- A low cost method of keeping track of engine performance.
- Standard wire length is 8 feet.
- Accurate means of setting exact engine RPM for proper operation of diesel engines.
- Requires vehicle power or external 9 volt transistor battery. (Replace 9 volt battery only once per year.)
- Has job timer and 2 service timers.
Apparently, it updates the display every .5 second, and the piezo pickup lead is a coax cable, so you'll not want to cut it unless you're good with soldering up coax.
Looks like a nice unit to me.
Mike
Mike
- Has thanked: 1 time
Could you hook it up to the alternator side idiot light circuit?
N_R
N_R
