Driveshaft support bearing replacement
Re: Center bearing fun/Replacing driveline? Comments needed
#31
Well .... it did it again.
I replaced ONLY the carrier / rubber cushion assembly about 1-1/2 yrs ago. The shafts always had some vibration in the 49-55 mph. So this time, I had the whole drive line assembly replaced. A local drive-line company made a new one complete. Is SO much better now. No vibration. The most shaking (whipping) occured when starting off on 1st with heavy load (500 lb+).
Is the new driveline one-piece (like OEM) or two-piece?
Did you pull it, or was it "drive through"?
What was your cost?
#33
asavage wrote:Is the new driveline one-piece (like OEM) or two-piece?
What was your cost?
1) My OEM and this replacement assembly is a two piece with middle bearing support and rubber doughnut (KingCab). Seems a single rear propeller is used in non-KC or for automatic transmission(?).
2) I'm not clear on what you're asking.
3) I have an ol friend who has contacts (everywhere) at a drive-line builder nearby who often builds propellers drives to spec. Whole job (R/R & new assembly) was $250.
philip wrote:1) My OEM and this replacement assembly is a two piece with middle bearing support and rubber doughnut (KingCab). Seems a single rear propeller is used in non-KC or for automatic transmission(?).
I've got driveshafts from three trucks and they're all two-piece, including a non-KC one.
That is less than half the last quote I got for a Nissan two-piece shaft.
#35
Q: Why were gentiles invented?
A: Somebody has to pay retail.
The new crosses each have a zerk.
