Anyone have experience running your Nissan diesel on the bench or ground, before dropping it into the donor car?
I bought my LD20T-II on ebay, and there's a youtube video of the thing running before they shipped it out. However, I'd like to do the same test, make sure the exhaust manifold gasket is OK, amongst other things (like extreme curiosity).
I've got diesel fuel in via a hand-pump, and I'm catching the excess. Got a good connection between the battery and the starter solenoid (and back), and using a starter test switch between the solenoid start wire and the starter feed. Getting plenty of juice to turn the starter.
Also using a trick davehoos outlined for the glow plug wire - connecting it to the solenoid start wire, so it'll only be engaged when the starter is.
Do I need 12v to the IP as well (gray connector in the foreground)?
The motor so far is not firing...
Also, on a completely unrelated note, why is there an oil pump on the back of the alternator?
Thanks in advance. I've learned more in a week about diesels from this forum than I thought possible.
