LD20 T-II u.s. owners rebuilt one?
Beware of craigslist scams.
That said.
My LD20T-II is just back from the shop, to diagnose why it would not run.
Low compression was the result.
Like 250 in 2. and 300 in other 2.
Leaking past rings., and 2 shot glow plugs.
SO, rebuild? or part out and move on?
Has anyone here in the states rebuilt one.
I need to know how hard the parts I will need are to get.
The starter was a nightmare. $300.00 special order from england.
So far, I have $1,600 in the motor.
Cut my losses, or spend a little more and have it rebuilt?
That said.
I can tell you that the pistons are not the same bore as the LD28, so you're going to have to source pistons/rings from overseas as well.
Check out page 10 of this pdf file for pistons - some oversize available.
http://www.bowdenengineparts.co.nz/pdf/pistons.pdf
Other parts available via the same website for LD20 I think.
USD is not bad against the NZD currently so check out the prices and do the calculations back to USD. we pay 12.5% sales tax (GST - goods and services tax) but thuis is about to go to 15% after the Govt budget i think but as an overseas buyer you'd most likely be exempt from paying this so be sure to clarify the oprice you are paying is GST excluded.
All the best.
Phil
All the best.
Phil
Timing belt/tensioner
Im out of Arkansas and would be interested in buying some parts off of you for a LD 20-II give me a call at 5016268812...
Thanks Andrew
Thanks Andrew
Thanks Andrew
Thanks Andrew
