Question on return fuel line and alternator
Quick questions
Can I plug the return line on the IP? Will it hurt the pump? anything else? I am running my LD28 in a land rover which doesnt have a return on the tank.
I think this will work but can I run the alternator by just running a ignition + lead to the S terminal and then 12 volts to the battery on the big terminal? I wont be using any warning lights. IE I dont think I need to worry about the L and R terminal?
Bought ready to fire this joker up! Gordo
Re: Question on return fuel line and alternator
Why not T it into the fuel line.JasperG wrote:Quick questions
...Can I plug the return line on the IP? Will it hurt the pump? anything else...
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
Anderson , SC
Since Fall 2009
- exmod110
just thinking out loud...
if u "t" the return line into the supply line how would u shut the engine off?
the shut off solenoid will shut off the correct inlet port, but now fuel can enter through the return line as it now see's the same fuel pressure as the inlet....?????
I guess it depends on where u "t" the line... b4 or after the pump.
and you do not want to just cap the return line off either.
What rover product is it going into?
85 Landrover 110 300tdi
02 Mazda protege5
02 Mazda protege5
Thanks for the help. I guess I am going to run a return line. Didnt think about shutting the engine down. I am running electric fuel pump that comes on with the key, do you think I need something else to shut it down?
Its going into a series rover on a Discovery frame. LT95 trans with an adapter plate. Spent the day working on the damn bellhousing as it was in the way of the starter. Grinding away and I thought I got enough of the area out of the way but the starter is still sticking I believe. Hell I dont even know if its good, but it works fine out of the vehicle? What a pain. Gordo
Users browsing this forum: Ahrefs [Bot] and 4 guests
