Kiki pump oil flow
cseger1
Kiki pump oil flow
Post by cseger1 »
I am putting my motor back together and all the various lines and hoses are off and I am trying to figure out the Kiki. I have the fuel in, and of course each cyl feeder line. I got the two vacuum lines sorted out. ANd I have the oil line that goes from the block into the banjo bolt on the side of the pump, lubricating the pump.
My question is, where is the oil return line?
Christian
1981 720 SD22
Post by Nissan_Ranger »
Oil drains out through the front of the pump back into the crankcase...
cseger1
Post by cseger1 »
So there's a port that drains oil into the area with the timing gears?
Christian
1981 720 SD22
cseger1
Post by cseger1 »
Nissan_Ranger wrote:Oil drains out through the front of the pump back into the crankcase...
Ah yes, I just looked at my scrap heap motor. It drains through the little ports by the shaft eh?
Christian
1981 720 SD22
ecomike
Post by ecomike »
I suspected that, but did not know for sure. Glad you got the answer. How is the project coming?
Mike
cseger1
Post by cseger1 »
ecomike wrote:I suspected that, but did not know for sure. Glad you got the answer. How is the project coming?
Moving, but slowly. The Volvo had an exhaust leak that turned out to be three missing bolts and one missing stud on the manifold. Which I tuned into no missing bolts and one totally stripped out stud hole in the block. Yay aluminum!. Heli-coil time in the tightest motor compartment known to man. I may be back on the SD22 in a day or two.
Christian
1981 720 SD22
