I am in washington state if you have one send me an email
smolyneux55@gmail.com
WANTED SD 22 TRANSMISSION OR BELLHOUSING
Unless your 1980 trans was behind an SD, it won't bolt up.
I put a 1980 trans into a 1982 SD "bellhousing" (really, the front case half) and that works OK, but you've got to have that SD "bellhousing" to make it work.
