Anyone attempt this conversion. Just curious.
I have a good sd22 motor and the 22re in my toyota needs major work. Big undertaking? :
________
Silver Surfer Vaporizer
sd22 into an 89' toyota 4x4?
It might be a little late, but this guy mated the w56 to the SD22. He is one of the best fabricators I have ever seen too.
http://board.marlincrawler.com/index.ph ... ;topicseen
1992 nissan pathfinder 4x4
1985 KC 720 4x4
1982 KC 720
1985 KC 720 4x4
1982 KC 720
- Has thanked: 1 time
Welding the SD starter bellhousing cone to the Toy bellhousing is tough work. There is no provision to adjust the starter drive gear-to-ring gear clearance on either design, so positioning before welding is critical.
I read a few pages worth forward in that thread to see if he had problems with it later, but there are 113 pages in that thread, and when I hit the homophobic shit on page six I gave up . . . someone else will have to dig for the info.
It worked fine for him, he took that thing all over the country. However he did swap a toyota diesel into it later for more power. As I understand he built, or someone else has built more than one of those bell housings allowing use of the SD22 on a toyota tranny.
There is some pretty good stuff in there too, such as running a super charger on the SD22 and lots of turbo stuff.
1985 KC 720 4x4
1982 KC 720
1985 KC 720 4x4
1982 KC 720
It didn't work fine by chance; he had to have done a good setup job, that's not easy. Not a procedure I'd recommend to someone who doesn't have excellent layout skills.bacho wrote:It worked fine for him . . .
Even aligned, it would still have to be faced (and probably bored) after welding, for long-term bearing reliability.
OTOH, an adapter plate might be fairly straightforward, at least for me. Maybe.
