SD22 starter problem
toyotapickup
Post by toyotapickup »
when the key is turned I can hear the starter spin it just not engaging with the flywheel its a gear reduction starter
1985 Toyota sr5 with sd22 and 5spd
Needs to be rebuilt and new clutch put in
See here
http://nissandiesel.dyndns.org/viewtopic.php?t=1474
been there, done that
If the re builder can keep your old pinion and it's not messed up then do so. Otherwise you could end up with the same issue that I had for a while till it wears in.
Or
Do what I did and "relieve" the back side of the new pinion gear with a die grinder.
Good luck
P
toyotapickup
I think I'm going to keep the starter and buy a new one and see if it fixes it what is the part number from napa and is a gr or dd starter better
Not sure about the part number from NAPA but I think there is a listing for it on this site someplace, and I even think you can go on to NAPA .com and find it there.
As for what better
There is a great debate about that.
I know on my SD25 I didn't think that I could put a DD starter in where the reduction one was. Something about the oil line for the vacuum pump but cant recall exactly.
I know it was pretty tight for the gr one. The DD one I think is just a titch longer.
Good Luck
Check here
http://nissandiesel.dyndns.org/viewtopi ... +variatons
Post by Nissan_Ranger »
You know, Paul... If you weren't here to answer some of this stuff, not much would ever get done!
Andy
dn29626
Post by dn29626 »
The DD for a SD22 is (or was) available through Oreillys.
Here is a current Oreillys link for a SD22 starter.
http://www.oreillyauto.com/site/c/detai ... rd=starter
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
That actually looks like the GR model.
dn29626
Post by dn29626 »
The link is to a GR. I did say current Oreillys link (above).
It is to the starter kept in stock.
I will try to relocate the DD i ordered.
EDIT: I found the DD info. From Oreillys.
My old thread listed it as Beck/Arnley 187-0354. When i entered it into the search on their site i got this http://www.oreillyauto.com/site/c/detai ... d=187-0354
The starter thread from 2010.
http://nissandiesel.dyndns.org/viewtopic.php?t=2420
Anderson , SC
Since Fall 2009
I have never really noticed a difference between the two starters other than the DD is harder to get in there.
Which one is supposed to be the best, the one that will turn the engine the fastest I expect, but if the engine is in working order, how would one ever find out.
The GR starters are easier to find though.
I tend to like the GR starters, but they both seem to work OK. I wouldn't kick either one out of my shop ;)
big0078
sd22 i have an sd22 motor and trans on a pallet and an 82 tr
Post by big0078 »
i have an sd22 motor and trans on a pallet and an 82 truck to get rid of cheap if you know some one who needs them phone 660 412 1451 names is Larry
BIG-O
elminero67
Post by elminero67 »
Just getting caught up on this thread, so I'm a "day late and a dollar short"...but if anyone does order the starter from O'Reilly's, they have both a gear reduction and a none gear reduction model. Over the years I've gone through three of them and they have a lifetime warranty, but every time I return one to O'Reilly's I seem to get a different version.
dn29626
Post by dn29626 »
Oreillys only shelf stocks the GR.
For the DD they also charge you the shipping. (Something about non-stock items and weight that they can get for you.)
Anderson , SC
Since Fall 2009
