NissanDiesel forums
It is currently Mon Oct 22, 2018 10:34 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: DCP Module relay
Post Number:#1  PostPosted: Mon Apr 07, 2014 4:58 pm
Offline
Common problem with the DCP Module relay contacts failing. I have owned an MQ Patrol from new in 1983 and started having problems with the relay contacts sticking and preventing engine shutdown. After many cleans the contacts finally had no metal left and the relay required replacement. Prices in aussie for a new DCP MOdule were prohibitive and the relay itself was not available so I searched for an alternative and found a suggestion in this forum that worked so here is what I did:
I bought a horn relay from Jaycar Electronics part number SY4047 which is a single pole double throw (SPDP) 24VDC 30A sealed relay with utilux terminals.
I then removed the old relay from the DCP Module, sucking the solder out of the PCB.
A five wire loom then was made up that connected from the PCB to the relay connectors through a hole cut in the top of the DCP Module.
The relay was then mounted on top of the DCP Module using some thick double sided tape. The hole was sealed with silicone glue.
All done! Cost? AU$6.50 for the relay and some wire and terminals from the workshop.
Why didn't I do that twenty years ago. If the relay fails just plug another one in!
Top
 Profile
 Post subject:
Post Number:#2  PostPosted: Thu Apr 10, 2014 4:41 pm
Offline
Good post.
_________________
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
Top
 Profile
 Post subject:
Post Number:#3  PostPosted: Fri Apr 18, 2014 4:27 pm
Offline
In 2008, my '83 Sentra's GP controller wouldn't do afterglow due to a failed relay, and I did pretty much the same thing.
(click image to go to the thread, with more pics)
_________________
Top
 Profile
Search for:
Jump to:
cron
