SD25 Inline IP / SD25 VE IP / TD27t FAQ
ehtrain
Post by ehtrain »
ok so recently I picked up another diesel which did run... last year I fixed it for a local who drove it until there was nothing left I guess. compression test says 300psi.... so it's not going far. So I just thought since nobody sees the sd25 apparently, and not likely have both engines for pictures so i will post pictures and notes that follow. sorry for the varrying picture quality as they are different years and camera's etc. For those that it may also apply the sd23 should fit into this area also as they shared the same block and many parts.
i randomly stumbled on rebuild info for:
-injection pump section FSM for the sd motors - http://www.4x4.ee/docs/nissan-SD-diesel ... d-3of3.pdf
-Cooling and lubrication FSM section - http://www.4x4.ee/docs/nissan-SD-diesel ... d-2of3.pdf
-General Information/ maintenance/ engine section of FSM - http://www.4x4.ee/docs/nissan-SD-diesel ... d-1of3.pdf
first off the 86 nissan 720 pickup with inline injection. VIN - JN6JD06S4FW000636 if im reading it correctly
here are the inline IP's pump info
line 1: 101441-9152
line 2: 541k432774
pump# 101044-8120
line 3: np-pes4a65c412rs2000np801
on the far side of tag assembly number: 16700-29w07
heres a decent shot of the alternator
ehtrain
Post by ehtrain »
now for the ve injection
things to notice:
1. oil filter and cooler housing are different allowing coolant passage to cold start device (csd) (wax pellet system similar to a thermostat but controlling cold start throttle linkage position)
2. power steering pump and bracket and no engine mounted reservoir
3. motor mounts are cast units not welded steel
4. air filter box on 720 has mounted baffle box, d21 is valve cover mounted
5. exhaust manifold is completely different shape and exit flange
6. intake has threaded section for air heater (720 uses dropping resistor by passenger headlight)
7. oil pan is single drain
8. starter (gear reduction on 720 over direct drive) (note gear reduction starter is longer and may not fit with d21 cast mounts)
9. front injection pump drive cover
10. water pump shaft is .25 inch longer on ve (don't quote me on that but water pump for 720 was .25in to short and water pump pulley hits housing)
11. transmission tail housing is completely different
12. fuel filter housing (d21 uses dual filter with heater and primer pump in one)(720 fuel primer is injection pump mounted)
13. cold start system (720 electric on/off/coldstart) (d21 electric fuel solenoid and csd linkage bumper)
14. injection pump rear cover (bolt up is 3 bolt on ve and 4 bolts on inline injection)
15.main drive pulley (ve is dampened with rubber and 2 belt, while other is 3 belt and solid steel)
16. alternator is interchangeable from both sd25's and td27 however the d21 body trucks have round plug and 60amp output while the 720 body has a "T" shaped connector and is 55amp. Also the vacuum pumps are different. The td27 and sd25 ve have the same vacuum pump however the oil pressure line on td27 in banjo and the sd25 is NPT. The td27pump banjo makes clearance for the turbo. I have installed the 720 alternator on the ve sd25 and it works but motor mounts make for clearance issues with the oil pressure and return lines, you will also need to jerry rig the plug.
17. vacuum pump (size/number of outlets is different but mounting appears to be the same as the td27t and the ve alternator, shaft length into the pump and spline appear similar never tried swapping)
18. the 720 has a torque damper attached to the transmission
19. td27 and sd25 VE both appear to have the same 3 bolt injection pump and mounting just has boost compensation
SO I will make a general note... after disassembling both types of sd25. it appears everything that bolts to the block is different but the lower oil block housing and oil cooler assembly that bolts into the block, the aluminium timing cover, valve cover, thermostat housing. The injectors are possibly the same
If you want more photo's of the VE diesel d21 look at thread here http://nissandiesel.dyndns.org/viewtopic.php?t=2923
VIN - JN6JD12S9HW000291
and for the reference sake here is the VE injection pump numbers. This is a rotary injection pump not turbo compensated
line 1: 16700 14G03
line 2: 104740-4790
if you look close you can see previous owner had water pump pulley spaced out with washers to allow for pulley clearance. This is not correct as the center of the water pump shaft centers the w/p pulley. by spacing the pulley out it will increase the load on pulley studs and likely cause belt slip issues
Imagehere
4x4 sd25 oil pump
2wd sd25 oil pump
d21 body fuel filter assy. ( fuel heater, primer, filter)
ehtrain
Post by ehtrain »
heres a couple pics of the td27t terrano (pathfinder) that I have 3spd w/OD auto, 4.66 gears, turbo 2.7 with altitude/boost compensation VE rotary injection pump. This has no maf or electronic injection timing that I can tell. It does have throttle position switch, fuel shut off solenoid, and a second 1 wire solenoid.
I also wanted to mention along with the alternator and plug being the same from both d21, td27 and sd25. I also have swapped glow plug relays and they are the same, however the datsun 720 relays were completely different. So as it would appear electronic wise the d21 vehicles (pickup, pathfinder, navara, terrano) share commonality. Where as the datsun/nissan 720 must be more proprietary to the older vehicles
VIN - WBYD21030319 (japanese look up only)
if you look between the steering shaft area you can see the turbo injection pump numbers for td27t VE injection
turbo compensated injection pump numbers
line 1: 16700-80G09
line 2: 104740-7132
again sd25 ve and td27t appear to have same injection pump, pump mounting position, and bolt pattern. They may be interchangeable!!!
ehtrain
Post by ehtrain »
ok so over the winter I have completely ordered all the sd25 parts need to rebuild an sd25 from nissan directly. minus the sleeves and wrist pin bushings everything is still available for the VE injected sd25.
new cam shaft - 13001-37509 -$464.28
Cam bearing - 13002-37501 -$23.92 (.std)
thrust bearing - 12280-37525 -$33.14 (.std)
rod bearing - 12117-y5211 -$75.84 (-.010/-.25mm)
main bearing - 12209-v1701 -$53.46 (-.010/-.25mm)
ring gear - 12312-37501 -$132.74
piston w/pin - 12010-t7205 -$397.00 (.std bore x height) (3 ring with alfin)
ring set - 12033-L2006 -$223.36 (.std)
lifter- 13231-78201 -$88.08
intake valve - 13201-L2000 -$79.44
exhaust valve - 13202-L2000 -$118.24
valve spring - 13203-T7200 -$36.48
rocker cover gasket - 13270-R8810 -$29.99
valve seat - 11098-L2000 -$69.76 (intake i think)
valve seat - 11099-L2000 -$77.64 (exhaust i think)
Intake/exhaust gasket - 14035-10G00 -$25.86
head gasket (mulit-layer metal) - 11044-09W01 -$98.63
valve stem seal - 13207-V1700 -$40.80
valve guide - 13211-V1700 -$195.36
push rod guide/protector - 11052-76203
all prices above are in CAD and the total cost of all the parts. many parts are individually listed numbers so your price may be different.
new cylinder liners are available from tieken and seem to do ok.
wrist pin bushings I'm getting the machinist to find if possible
I can order these parts for anyone if they cannot order them themselves.
I have all the numbers for the hoses and thermostat etc also. ill see if i can sort out what number is what later
ehtrain
Post by ehtrain »
heres a couple shots of the alternators I had off. I have the 720 alternator off also so I should take some pics and measure the rear shaft.
on the right is the td27t alternator and on the left is the sd25 VE (d21)
-both vacuum pumps appear to be the same minus how the oil feed lines are attached.
-get a decent shot of the round edge rectangular alternator plug
td27t on bottom and sd25 ve on top
here are some shots of the above listed parts that are still currently orderable
ehtrain
Post by ehtrain »
its crappy and raining today plus my shoulder is still healing from surgery so I thought Id type out some engine specs for the sd25. since some people may not find the pdf's online etc. this will make its quick reference for anyone. I did my best to proof read all my typing! If anyone sees mistakes please correct them or INFORM ME!
things to note: majority of rebuild info that follows sd25 also follows sd23 minus 4.2mm difference in rod length specs and 46mm crank throw instead of 50mm like sd22,sd25,sd33.
engine type: SD25 & sd23 according FSM
L/(CID): sd25 - 2,488cc/sd23 - 2,289cc Diesel
number of cylinders: 4
bore x stroke SD25: 89mmx100mm or 3.5039x3.9370in
bore x stroke SD23: 89mmx92mm or 3.5039x3.6220in
Fire order: 1-3-4-2
compression ratio @ rpm: 2.94MPa@200rpm <294kpa difference OR 426psi at 200rpm with 42psi difference highest to lowest
oil pressure: 35psi
oil capacity: 5.5L
oil grade: 15w-40 API CC or CD
injection timing (degrees btdc/rpm): 20/600(18/600 for 720 model) 8/600 VE type
BLOCK
bore diameter: 89 - 89.035mm(3.5039 - 3.5053in)
overbore diameter: N/A
max bore taper: 0.02mm(0.0008in) @ 156mm or 6.14in down cylinder
max bore out of round: 0.02mm(0.0008in) @ 20mm or 0.79in down cylinder
liner flange protrusion: 0.02 - 0.09mm(0.0008 - 0.035in)
liner height deviation: less than 0.05mm(0.0020in)
liner counter bore: -0.03 to -0.08mm
liner wear limit: 0.3mm(0.012in)
crank housing bore: 74.981 - 75mm
cam shaft bore journals:
#1 48.641 - 48.666mm
#2 47.117 - 47.142mm
#3 44.425 - 44.450mm
Block deck height: 268mm (deck limit 267.72mm or 10.54in)
longitudinal warp limit: 0.10mm or 0.0039in
transverse warp limit: 0.02mm or 0.0008in
Liner to block interference fit: 0.02 - 0.09mm(0.0008 - 0.0035in)
pilot bushing insert depth: 3.5mm(0.138in) from flywheel mount surface
PISTONS & RINGS
piston to bore clearance: 0.09 - 0.115mm(0.0035 - 0.0045) @ 70mm w/3 ring piston or 2.75in from crown (720 model 0.08 - 0.105mm or 0.0031 - 0.0041in) (50mm from crown for 5 ring applications)
piston wear limit: less than 0.15mm(0.0059in)
piston outside diameter: 88.895 - 88.935mm(3.4998 - 3.5014in)
piston ring to groove clearance:
3 RING
#1 0.06 - 0.10mm(0.0024 - 0.0039in) limit 0.5mm or 0.020in
#2 0.04 - 0.08mm(0.0016 - 0.0031in) limit 0.3mm or 0.012in
#3 0.02 - 0.06mm(0.0008 - 0.0024in) limit 0.15mm or 0.0059in
5 RING (FSM does NOT list sd23/sd25 as having 5 ring, only sd22,sd33)
#3 0.04 - 0.08mm(0.0016 - 0.0031in) limit 0.3mm or 0.012in
#4 0.02 - 0.06mm(0.0008 - 0.0024in) limit 0.15mm or 0.0059in
#5 0.02 - 0.06mm(0.0008 - 0.0024in) limit 0.15mm or 0.0059in
ring end gap:
#1 0.30-0.45mm(0.0118 - 0.0177in)
#2 0.20-0.35mm(0.0079 - 0.0138in)
#3 0.15-0.30mm(0.0059 - 0.0118in)
limit 1.5mm or 0.059in
piston pin to piston interference fit: -0.007 to +0.010mm(-0.0003 to +0.0004in)
piston pin diameter: 25.993 - 26mm(1.0233 - 1.0236in)
piston pin bore diameter: 25.990 - 26mm(1.0232 - 1.0236)
piston protrusion: -0.27 to +0.08mm(-0.0106 to +0.0031in) limit -0.4 to +0.3mm(-0.016 to +0.012in)
piston to rod clearance: 0.025 - 0.045mm(0.0010 - 0.0018)
CONNECTING RODS
bend: less than 0.05mm(0.0020in)
torsion: less than 0.05mm(0.0020in)
small end bushing inside dia.: 26.025 - 26.038mm(1.0246 - 1.0251in)
small end bore: 28.987 - 29mm(1.1412 - 1.1417in)
big end bore: 55.987 - 56mm(2.2042 - 2.2047in)
big end bushing inside dia.:
piston to rod clearance: 0.025 - 0.045mm(0.0009 - 0.0017)
center to center SD25: 170mm(6.6929in)
center to center SD23: 174.2mm(6.86in)
rod thrust clearance to crank web: 0.1 - 0.2mm(0.0039 - 0.0078in)
connecting rod oil clearance: 0.035 - 0.087mm(0.0014 - 0.0034in)
rod offset: 1.5mm(0.059in) #1,3 and rod #2,4 are offset the same direction
CRANKSHAFT
main journal: 70.907 - 70.920mm(2.7916 - 2.7921in)
rod journal: 52.913 - 52.926(2.0832 - 2.0837in)
out of round: 0.01mm(0.0004) limit 0.02mm(0.0008in)
taper: 0.01mm(0.0004in) limit 0.02mm(0.0008in)
crank shaft bend: 0 - 0.03mm(0 - 0.0012in) limit 0.10mm(0.0039in)
main bearing oil clearance: 0.035 -0.093mm(0.0014 - 0.0037in)
thrust bearing thickness: 2.36mm(0.0929in)
end play: 0.06 - 0.14mm(0.0023 - 0.0055in) limit 0.40mm(0.0157in
crank shaft throw: sd22, sd25,sd33 50mm(1.9685in)
crank shaft throw: sd23 46mm(1.8110in)
CAMSHAFT
camshaft to bushing oil clearance:
#1 0.024 - 0.102mm(0.0009 - 0.0040in)
#2 0.037 - 0.115mm(0.0015 - 0.0045in)
#3 0.024 - 0.102mm(0.0009 - 0.0040in)
bend: 0 - 0.03mm(0 - 0.0012in) bend limit 0.06(0.0024)
end play: 0.08 - 0.28mm(0.0031 - 0.0110in) limits 0.5mm(0.020)
lobe height limit: 36.8mm(1.449in)
lobe height std.: 37.28 - 37.32mm(1.4677 - 1.4693in)
cam journal diameter:
#1 45.434 - 45.447mm(1.7887 - 1.7892in)
#2 43.897 - 43.910mm(1.7282 - 1.7287in)
#3 41.218 - 41.231mm(1.6227 - 1.6232in)
CYLINDER HEAD AND VALVETRAIN
lifter diameter: 12.666 - 12.684mm(0.4987 - 0.4994in)
lifter hole diameter: 12.700 - 12.718mm(0.5000 - 0.5007in)
pushrod bend: less than 0.5mm(0.020in)
Valve spring out of square: less than 1.3mm(0.051in)
valve spring pressure: 61.1kg@30.4mm(134.7lbs @ 1.197in)
valve spring free length: 50.35mm(1.9822in)
valve spring installed height: 30kg@ 39mm(66lbs @ 1.54in)
valve angle: 44.5-45.5 degrees
valve length: int/exh 117mm(4.6063in)
valve margin limit: 1.5mm(0.0590in)
valve head diameter:
INTAKE: 40mm(1.575in)
EXHAUST: 34mm(1.339in)
valve stem diameter:
INTAKE: 7.970 - 7.985mm(0.3138 - 0.3144in)
EXHAUST: 7.945 - 7.960mm(0.3128 - 0.3134in)
valve stem surface grind limit: 0.2mm(0.008in)
valve guide inner diameter finished: 8.00 - 8.015mm(0.3150 - 0.3156in)
valve guide outter diameter: 12.033 - 12.044mm(0.4737 - 0.4742in)
valve deflection limit: 0.15mm(0.0059in)
valve guide to head interference fit: 0.022 - 0.044mm(0.0009 - 0.0017in)
cylinder head valve guide bore: 12.00 - 12.011mm(0.4724 - 0.4729in)
valve stem to guide clearance:
INTAKE 0.015 - 0.045mm(0.0006 - 0.0018in) limit 0.15mm(0.0059in)
EXHAUST 0.04 - 0.07mm(0.0016 - 0.0028in.) limit 0.20mm(0.0079in)
Rocker to rocker shaft oil clearance: 0.02 - 0.05mm(0.0008 - 0.0020) limit 0.15(0.0059in)
valve clearance: 0.35mm(0.014in) HOT
rocker shaft diameter: 19.98 - 20.00mm(0.7866 - 0.7874in)
rocker arm inside diameter: 20.02 - 20.03mm(0.7882 - 0.7886in)
rocker shaft bend: 0 - 0.1mm(0 - 0.004in) limit 0.3mm(0.012)
head to valve distance(valve recession):
INTAKE: 0.275 - 0.675mm(0.0108 - 0.0266in) limit 1.25mm(0.0492in)
EXHAUST: 0.305 - 0.695mm(0.0120 - 0.0274in) limit 1.25mm(0.0492in)
head height limit for resurfacing: 89.7mm(3.5314in)
prechamber protrusion: 0 to +0.07mm(0 - 0.0027in)
cylinder head warp: less than 0.2mm(0.008in)
FUEL SYSTEM & TIMING
flywheel runout: less than 0.15mm(0.0059in)
cam gear backlash: 0.07 - 0.20mm(0.0028 - 0.0079in) limit 0.30mm(0.0118in)
injection pump gear backlash: 0.07 - 0.020mm(0.0028 - 0.0079in) limit 0.30mm(0.0118in)
front plate warp: 0.2mm(0.008in)
injector crack pressure:
inline pump: 2,489psi
VE pump: 2133-2204psi
injection timing measurement VE pump:
sd25: 0.89 +- 0.02mm(0.0350 +- 0.0008in)
sd23: 0.94 +- 0.02mm(0.0370 +- 0.0008in)
sd22: 1.03 +- 0.02mm(0.0406 +- 0.0008in)
sd22: 0.95 +- 0.02mm(0.0374 +- 0.0008in) ONLY IP # 104749-4040 and 104749-4080
v-belt deflection: 8-12mm(0.31 - 0.47in)
ENGINE INTERNAL PARTS TIGHTENING TORQUE
main bearing cap: 123-127ft/lb (3 stages to reach spec torque following proper tightening sequence
crank pulley nut: 217-239ft/lb
flywheel bolts: (loc-tite required)
3 main bearings: 33-36ft/lb
5 main bearings: 65-72ft/lb
bolt w/washer: 94-108ft/lb
front cover bolts:
m6 2.9-4.3ft/lb
m8 7-9ft/lb
front end plate bolt: 7-9ft/lb
cam gear bolt: 33-36ft/lb
oil pump bolt: 9-14ft/lb
oil pan bolt: 5.1-7.2ft/lb
cylinder head bolt: (done in 3 stages of proper sequence to reach proper torque)
sub: 33-40ft/lb
main87-94ft/lb
rocker shaft bolt: 14-18ft/lb
rocker arm nut(tappet): 14-18ft/lb
camshaft thrust plate: 2.9-4.3ft/lb
connecting rod cap bolts: 49-52ft/lb
rocker cover: 7-9ft/lb
piston oil jet: 22-29ft/lb
cam/crank gear oil jet: (NPT fitting)proper direction as indicated in fsm
ENGINE OUTER PARTS TORQUE
glow plug: 11-14ft/lb
oil drive cap bolts: 9-14 ft/lb
crank breather: 5.8-8 ft/lb
fan mount nuts: 5.1-6.5 ft/lb
water outlet: 7-9ft/lb
water pump bolt:
m8 7-9ft/lb
m10 14-18ft/lb
manifold nut & bolt: 11-13ft/lb
injection pump mounting nut:
inline injection: 14-18ft/lb
VE injection: nut - 14-18ft/lb bolt - 12-16ft/lb
CAV/DPA: 11-14ft/lb
injection nozzle to cylinder head:
for nozzles # 16600-90060, 16600-36w00, 16600-t9000: 43-51ft/lb
for nozzles # 16600-37502, 16600-90012, 16600-90019, 16600-j5571, 16600-t3401, 16600-t3470, 16600-t6200, 16600-t6201, 16600-y8400, 16600-y8401: 51-58ft/lb
oil cooler bolt: 7-9ft/lb
oil cooler pipe nut: 7-9ft/lb
timing gear cover: 7-9ft/lb
injection pump timer nut: 43-51ft/lb
injection pump drive gear nut VE: 43-51ft/lb
injection pump drive gear CAV-DPA: 11-14ft/lb
feed pump gear CAV-DPA: 11-14ft/lb
injection tube flare nut: 22-25ft/lb
injector spill tube cap nut: 29-36ft/lb
oil filter bracket (aluminium lower oil filter housing): 20-27ft/lb
alternator mounting bracket: 20-27ft/lb
alternator to alternator bracket: 20-27 ft/lb
alternator to adjustment bar: 8-10ft/lb
diesel pump controller: 7-9ft/lb
diesel pump controller bracket: 33-45ft/lb
thermostat housing: 7-9ft/lb
fuel shut off solenoid VE pump: 14-18ft/lb
timing plug bolt VE pump: 5.8-7.2 ft/lb
ehtrain
Re: sd25 inline injection / sd25 VE / td27t FAQ
Post by ehtrain »
here's some break down sheets. I think its the number on bottom right corner that dealer types in to pull up the schematic
VE injected sd25 (d21 body canada)
ehtrain
Post by ehtrain »
for the 720 truck with sd25 inline injected.
ehtrain
Post by ehtrain »
and for some td27t diagrams
Most excellent and thanks for posting all that.
I am wondering if you have a picture of the fuel heater that was used on the D21. I see the fuel strainer that you have posted for the 27 and mine looks very much like that only is a double wide unit that fits to the fire wall. The water trap is on one side and the heater fits into the top of it. The primer pump and filter is next to it.
The heater quit working a couple years ago and I have had it apart and the heater element is replaceable but don't know the part number to look up/search .
Thanks
ehtrain
Re: SD25 Inline IP / SD25 VE IP / TD27t FAQ
Post by ehtrain »
best i can do for the filter assembly. maybe there is a part number on the heater somewhere?
filter - 16403-09W0A
Filter - 16405-10g03
upper filter o-ring - 16406-18g01 -? may or may not be correct
water level sender - 16412-10g00 - not in production
fuel temp sender - 16412-10g06 - not in production
Thanks Mr.
I have those pics and even have a spare water trap etc. Finding the heater however has been a quest.
Looked at a Kubota part I thought would work but too much modification needed.
ehtrain
Post by ehtrain »
I can't say I've really paid any attention to fuel filter assemblies when I service machines. But I don't recall seeing many fuel warmer/heaters on anything else. Do you believe this would help much given up here winter diesel is used? I figured it might help filter flow/seperation slightly but can't figure out the theory behind it. unless its like -50c outside without wind.... get close here in the winter.... haha
Your right, and so far I have not run into any issues however my OCD side sees a part that's not working.
I know ....... weird.
ehtrain
Post by ehtrain »
hahaha I get fussy with some things like that too. But given the age of this stuff and the simplicity I'd almost just want to delete the wiring just to be tidy. I want to find the specs of some other filter assemblies as something slightly different shape in my trucks case may make filters easier to change. I deleted the factory mounting bracket "thing" for a piece of angle iron since I could not conceive of how nissan figures the filters are easily spun off -on during and oil change without a bunch of bolts involved. Mind you I am VERY fussy about filter changes. oil is always every 5,000km and fuel filter every 10,000km. If I had a drain valve like the td27 or the 720PU then I might risk 15,000KM or 2 filters a year with draining every oil change.
