Hi all, I have bought a LD28 to upgrade from the SD23 in a bedford.
The van already has a floor change 5 speed from the sd23, can I use this box and flywheel on the LD28?
If I need a new bellhousing, does any one have one for sale?
LD28 to upgrade from sd23 (gearbox info needed)
- dieseldorf
Re: LD28 to upgrade from sd23 (gearbox info needed)
You have to find a housing from a L-Series engine, 4 or 6 cylinder.
