SD-22 Bottom End View
This is the SD22 bottom end. When fitting new bearings, BE SURE you get the bearing set for the three main SD22. The main bearings have the same diameter for the SDxx four cylinder engines.
BUT ...
There seems to be a pervasive mis-cataloging that says 1980-1986 SD22 have 5 mains ... which they do not. The SD22 has only three mains.
The SD23 and SD25 have 5 mains with the same journal diameter as the SD22 but they are about 1/4" narrower.
It seems the workaround to get the right bearing set for your 3 main SD22 is to specify a pre 1980 SD22.
(Block, crank, and center main cap courtesy of G.Guest, bearing set from A.Savage)
Center Main Bearing Cap
Re: SD-22 Bottom End View
philip wrote:Image
Sealed Power & Clevite do have the correct three main bearing shell kit if ... you ask for any year SD22 that is PRE 1980. Where all cataloging falls apart is in listing POST 1980 SD22 engines as having five mains.
The correct Sealed Power number is 6765M while the Clevite number is MS1118P.
moose60
Post by moose60 »
I was crusing Ebay today and saw this...
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 8034506735
Which seems to support your information. Clevite has the info wrong.
Byron
82 Datsun 720 KC SD22
MPG Machine
There are 10 shells in that box. There are 5 mains in SD23 & SD25 engines. To get the right shells from Clevite, request bearings to fit pre 1980 SD22. The 3 main SD22 shells are quite a bit wider.
Al can tell you more in detail.
Anybody know if the SD33 main brgs are the same as an SD22's? I'm looking at an eBay auction for a set of SD33 brgs. for use in an SD22.
steven.0424
sd 22 mains
Post by steven.0424 »
in my manual phil it does statesd22 does come with both three or five mains sd22-703539~
DieselTok
Post by DieselTok »
You guys are saying that the SD22 was ONLY fitted with 3 main bearings. But here I have a 1984 SD22 from a 720 truck in my Mazda B2000 '87 truck. It says SD22 on the block and on the valve cover.
What do you say about that?
C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_139511_2NC5XVNYRHOGW1453651196.jpg
C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_139511_2NC5XVNYRHOGW1453651196.jpg (258.29 KiB) Viewed 6964 times
C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_139511_F7DWK1Z677ED1453651196.jpg
C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_139511_F7DWK1Z677ED1453651196.jpg (408.09 KiB) Viewed 6964 times
Mazda B2000 '87 w/ Nissan SD22
Actually, the post above yours from 8 years ago points that out.
DieselTok
Post by DieselTok »
Yup, I know. But I just wanted to apply with some photo evidence to the topic :)
Thanks for sharing
DieselTok
Post by DieselTok »
plenzen wrote:Thanks for sharing
Hahaha! You're welcome! :mrgreen:
