LD Smoke on acceleration
nissan_nerd
Post by nissan_nerd »
Whenever I accelerate from a stop in my LD Maxima, a giant cloud of smoke flys out of my exhaust. Air filter and fuel filter are new, and I cleaned out the intake grunge. I am do for a valve adjustment (taking care of it next week), but still kind of stumped.
I heard these IPs have an internal vein lift pump that stops working resulting in no injection timing advance. Is it possible to use an external electric lift pump to solve this?
1982 Maxima Diesel
1977 810 RB20DE
dieseldorf
Re: LD Smoke on acceleration
Post by dieseldorf »
Your lift pump is OK, otherwise your engine would not start or die soon after. Most likely you have leaky/worn injectors.
nissan_nerd
dieseldorf wrote: 2 years ago Your lift pump is OK, otherwise your engine would not start or die soon after. Most likely you have leaky/worn injectors.
Is there any way to service them? All parts seem to be NLA for years now…
1982 Maxima Diesel
1977 810 RB20DE
dieseldorf
Try to locate Bosch Diesel Service in your area. Otherwise contact these guys: https://dieselcare.store/
A few years ago, they quoted me $60.00 a pop, to rebuild the injectors, incl. new nozzles.
Also, I would use fuel additive to lubricate and clean the IP and injectors. Search this forum for EGR delete. It might help with smoking.
