Surging during light throttle
zen
Post by zen »
SD33 now turbo,was n/a..has always "surged" on light loads ie keeping to 30mph hardly any throttle,can drive out of it by giving some gas, or releasing throtle..
Now have done search on this very recently discovered kool forum and it seems possible cause is dodgy diaphragm on pump..ie gone hard??don't think its holed as can get really good fuel figures if i wish..ie 27 MPG..any thoughts?? oh otherwise engine is sweet..
turbo it
Re: Surging during light throttle
zen wrote:sd33 now turbo,was n/a..has always "surged" on light loads ie keeping to 30mph hardly any throttle, can drive out of it by giving some gas, or releasing throtle.
From a governor perspective, surging is most often the result of the fuel rack being modulated back and forth instead of being held steady. For instance, when a small hole develops in the pneumatic governor, the size (and therefor the leak) may vary with the diaphragm's deflection. Also, when there is resistance to movement (tar, goo) on the rack linkage betwen the pneumatic and mechanical governor, the rack's movement may become notchy. Pneumatic Governor
From a fuel delivery perspective, a series of air bubbles arriving at the injection pump can bring about surging. Purging Air
zen wrote: Now have done search on this very recently discovered kool forum and it seems possible cause is dodgy diaphram on pump..ie gone hard??
Glad you found nissandiesel / SD22 forum. Al and I hope to maintain a reference site of reliable information. The Pub is across the street. :wink:
zen wrote: Dont think its holed as can get really good fuel figures if i wish..ie 27mpg..any thoughts?? oh otherwise engine is sweet..
"Holed" is a matter of degree. When a hole becomes a tear, then you will have unmistakable driveability and fuel consumption complaints.
zen
Post by zen »
thanks..will be checking (well replacing) the diaphragm..(if i can find one here)
there is no smoke when surging..(its not bad, just annoying..now that i have replaced the transfer box, props etc. (was bad with shagged transmission))
and checking for air in line..(you never know)
oh. wot to coat new diaphragm with...not cod liver oil that is for sure!! silicon oil??
turbo it
zen wrote:thanks..will be checking(well replacing) the diaphram..(if i can find one here) _SNIP_
oh. what to coat new diaphram with...not cod liver oil that is for sure!!silicon oil??
Jury is still out. Obviously the leather "preservative" needs to resist polymerization under operating conditions (temperatures possibly reaching 200 degrees F).
Has thanked: 3 times
Don't we have an ongoing thread about the diaphragm lubricant?
asavage wrote:Don't we have an ongoing thread about the diaphragm lubricant?
HERE. but some people just don't want to meddle with stuff when "it don't need fixin'". Now you or I would without trepidation whip those screws out, pull the cover off, and take stock of our experiment. :wink:
zen
Post by zen »
finally got around to sorting this surging out...
twas the inlet/exhaust gasket leaking a wee bit...replaced and all sorted now..
turbo it
zen wrote:finally got around to sorting this surging out...
Does your SD33 have an operational EGR system?
zen
Post by zen »
no Philip..
It didn't come with one..infact i have never seen one on the SDs over here at all...( i envy just about everything in cali (compared to england) except your emission laws and the amount of guns! :wink: )
turbo it
the-486
Post by the-486 »
what does Surging sound like?
-the 486 kid
1981 720 KC SD22 169K+ B-100 " RUST BUCKET! "
1979 Mercedes 300SD 290K+ B-100 / SVO!
1995 P-30 Step-Van, Cummins 4BTa,SVO Campervan!
zen
Post by zen »
it was the engine hunting..abit like a learner kangerooing but nowhere as bad..caused this time by air leak on inlet manifold gasket upseting the ip.
turbo it
