If you need it or part of it, let me know. I will test it and make sure it works and send it to you for your work with the clock.On the Wagon WW res: I can't recall if my '83 Wagon needs one or if it only needs one of the pumps.
Try the big hammer83_maxima wrote: Time control unit failure? We know the clock is good, so why no workie?
But Al spent all kinds of time fixing this clock and we KNOW it works, so we need to find out why it does not work in THIS car...kassim503 wrote:Try the big hammer83_maxima wrote: Time control unit failure? We know the clock is good, so why no workie?![]()
Epoxy in a clock from a early 90's civic or accord I forgot, then solder up all the wiring and have a adjust switch hidden under the dash like I did, the only regret is the clock is too dim to read when driving with the lights on during the day. Otherwise its worth your while, especially if you stare at the clock in rush hour traffic.
Try the bigger hammer83_maxima wrote: But Al spent all kinds of time fixing this clock and we KNOW it works, so we need to find out why it does not work in THIS car...
1836 S Downing St.kassim503 wrote: [Maxi related]
I found a ECU for my car, where do I ship yours back? I lost your adress
Will do. I'll let you know what I find.asavage wrote:Ben:
Print out this scan, then dbl-check that I put the wires back in your connector correctly.
