Curious,
dieselhund
1981 Nissan Maxima diesel stn. wagon
1981 Nissan 720 diesel kingcab
1989 Iveco 15-14 tow truck
1980 DB 300 TD non-turbo
So...asavage wrote:SNIP The 1981 AT is the least-desireable of the three ATs available. Read why at the Transmission section of the FAQ.
So far, so good . . .philip wrote:Every year had a different model AT:
1981: 3N71B = conventional 3-spd AT*
1982: L3N71B = 3-spd w/lockup converter
1983: L4N71B = 3-spd w/lockup converter + OD
The L4N71b has an additional planetary gearset ... making it a 4-spd plus converter lockup . . .
As I understand it, it's all hydraulic. On the Maxima (AFAIK) there is a single solenoid that allows one to cancel the OD function. It isn't necessary to have it connected.. . . that requires electronic support to locj the torque converter?
I don't know.Will this transmission also lock the torque converter in 3rd gear under predetermined circumstances or if OD is blocked?
And the MPV as well. Actually, there's a whole bunch of vehicles that used it. However, the later ones are electronically controlled to a greater extent and probably do require support electronics. Somewhere, DaveHoos expounded on the function of the later ones. Did you read the L4N71b thread?On the net, I find many references to Mazda B2200 having the L4N71b.
So ... this non-electronic trans shifts 1,2,3,4, with lockup occuring at a fixed vehicle speed once in 4th.asavage wrote: As I understand it, it's all hydraulic. On the Maxima (AFAIK) there is a single solenoid that allows one to cancel the OD function. It isn't necessary to have it connected.
I tried to follow DaveHoos' L4N71b post. He did not address the normal shift order of the non-electronic and electronic versions.asavage wrote:SNIP Somewhere, DaveHoos expounded on the function of the later ones. Did you read the L4N71b thread?
