Coolant Line Elbow
- TooManyIdeas
Coolant Line Elbow
Got another thread pitch question. The elbow fitting that goes from the heater hose line to the thermostat housing, what size is it. I noticed in Phillip's The Bomb thread the fitting looks aftermarket. What I'm trying to do is install a thermostatic control for an electric fan, so I want to Tee into that port. Unless one of you ingenious fellows has a nifty McGyveresque way to piggyback off of the temperature sending unit
85 Chevy Monte Carlo CL
90 Toyota Pickup -SOLD
05 Kia Spectra 5
02 Dodge Dakota Quadcab
-OOOOOOOOHHHHHHHHH YEAH!!!!!
05 Kia Spectra 5
Re: Coolant Line Elbow
Whoneeds a fan at all? The only time my truck's A/C suffered was in 100* heat at speeds below 30mph. Serious. That said, an idling diesel generates little heat. More fuel delivered makes heat.TooManyIdeas wrote: What I'm trying to do is install a thermostatic control for an electric fan, so I want to Tee into that port.
If the sensor has a small thread, I'd be inclined to drill / tap another hole in the thermostat housing as there is room.
- TooManyIdeas
Philip, so your trying to tell me you don't run ANY type of fan at all
. All I want to do is allow the heat from the engine to control the fan. If that heat never turns the fan on, then so be it. However I'd still like to have the insurance.
05 Kia Spectra 5
05 Kia Spectra 5
The "no fan" experiment I ran showed me how much cooling reserve the SD has ... and my truck has an A/C condensor blocking some of the air flow.TooManyIdeas wrote:Phillip, so your trying to tell me you don't run ANY type of fan at all.
As I recall, some electric fan kits use a thermo-switch whose sensor fits (jambs) in between the radiator fins and is adjustable. That's pretty simple and ... it's adjustable.
- Has thanked: 4 times
I like the bulb-sensing style. The one I've been recycling through various vehicles I bought in the very early 80s. It slips into the upper (or lower) radiator hose. There tends to be a leak of coolant around bulb's tether, so I cut a couple of small strips of bicycle inner tube to make the transistion around the tether less dramatic, and also applied RTV (in addition to a std hose clamp, of course). The bulb reads the coolant directly.
I bought a thermostat housing today at the JY. Before I removed it though, I broke the heater ell loose. I can guarantee that the thread pitch is too fine to be an NPT size. Though it's a taper fitting, it's not SAE. I will try to measure it tomorrow, but it's likely metric or BSP -- probably the former.
Looking again at Galen's pics in "The Bomb" thread, the from the thermostat housing (the hot line to the heater), looks painted OEM to me. The brass-colored return line (cool line from the heater) might be something else. The JY engine I looked at today was missing the WP, so my mind is not fresh on that one.
Anyway, if you were hoping to use a 1/2 MNPT fitting, forget it, unless you re-tap the housing.
BTW, I have a spare housing
I am planning on putting three new 8mmx1.25 helicoils in it, and putting it on a shelf as a spare -- so many folks here seem to have problems with the OEM vertical bolts breaking off in it. But if you really want one, I could be persuaded to part with it.
- TooManyIdeas
Be careful when using helicoils on anything around liquids or gasses. They were not designed to seal anything. There only purpose is to repair damaged threads on solid mounting points. If your plan is to thread something near liquid or gas, you need to use a solid threaded insert IE slimsert or keensert.
Anywho, tell me which dead presidents I need to resurrect and let's make a deal (no whammy)
05 Kia Spectra 5
05 Kia Spectra 5
There is no sealing needed on this part, the sealing is all done at the gasket. Time-serts are what I would use in a thread-seal situation, but that's rare for the thread repair I usually do.
This housing does come with the two sensors (one for GP controller, one for temp gauge) and the ell. If you want it that way, how about $20 and I pay the shipping (which is probably half of that).
If you don't want the sensors, cut a couple bux off. I have spare sensors on the "Vashon Truck" engine, so I don't really need these. And they don't seem to go bad very often.
I can take pics before sending if you'd like. The housing, and the camera, are at work. Earliest pics probably Tues. night, as I will probably be tied up Monday night.
True, the thermostat cover gasket does the sealing. But that paper gasket is not a perfect seal and ... the three bolt holes are blind holes (dead end). So ... seepage past the paper gasket reaches the bolts and corrodes them as there is no drainage path. Busted bolts result.asavage wrote:There is no sealing needed on this part, the sealing is all done at the gasket.
After having the broken bolt (or was it two) melted out, I replaced the rust prone OEM bolts with stainless dipped in antisieze grease.
My statement was in response to TMI's that helicoils are not suitable for use in sealing gasses/liquids.philip wrote:True, the thermostat cover gasket does the sealing.
I advocate for steel or SS inserts wherever there is any question about the durability or longevity of a tapped hole in a non-ferrous metal.
Not only does a helicoil prevent galling & siezure (unless you run SS hardware too, in which case anit-sieze is mandatory), the threads themselves are stonger than the parent metal, and the OD of the helicoil insert has more surface area than the original hole.
I always coat the OD of the insert with Lock-Tite.
I really like helicoils. Time-serts and the like seem to work well too, and don't have the issue with gaseous/liquid leakage through the insert.
Ya got me!TooManyIdeas wrote:Got another thread pitch question. The elbow fitting that goes from the heater hose line to the thermostat housing, what size is it.
It isn't 18 TPI and it isn't 20 TPI.
It isn't 1.25mm pitch and it isn't 1.5mm pitch.
Somebody with more time/knowledge than me is going to have to suss this one.
- TooManyIdeas
Ok I found out that the elbow is 3/8 NPT so that's cool. However what are the two probes wired to. One has got to be the temp guage, but I'm clueless as to the second one (and I can't find my FSM to figure it out)
could some one tell me what each of those sensors are
05 Kia Spectra 5
05 Kia Spectra 5
Re: More stupid questions
You already know what the single post sensor is for.TooManyIdeas wrote:-SNIP- Could some one tell me what each of those sensors are
The two-post sensor is for glow plug control. Scroll down to the Type I schematic.
Also Adaptor plug / harnass view.
No, it's not. 3/8 NPT is 18 TPI, and that elbow is definitely not 18 TPI.TooManyIdeas wrote:Ok I found out that the elbow is 3/8 NPT
While I don't doubt that you can screw 3/8 NPT in, it's not the correct thread pitch.
