Parting out 83 Maxima diesel wagon
I just found that I have a near-perfect pad for above the glovebox, in brown. If you want it, just pay shipping from 98368.odie wrote:And the dash pads too.
I also have a brown knee bolster (the under-dash cover on the driver's side, the one with the Talking Lady module bolted to its topside), same deal. Even has the plastic dzus fasteners.
- Midnightz
Sounds great! My lady speaks like the Whos...I feel like Horton. If I try really really hard, I can almost hear what she is saying.asavage wrote:I just found that I have a near-perfect pad for above the glovebox, in brown. If you want it, just pay shipping from 98368.odie wrote:And the dash pads too.
My dash pad over the driver is all cracked and the glove box door is gone so I'm hoping Midnightz has a good parts for me.
I saw the picture of that hitch too, got me wanting one...
The pad over the glove box is still intact but I can see the end starting to let go.
I'm traveling right now so I'm borrowing computers.
1983 Maxima LD28..sold
1981 Rabbit diesel - sold
1987 MB 300TDT diesel...sold
- Midnightz
Pulled the engine last night and getting close to pull all the useful/claimed parts.
See the original post to see the list of the parts that are claimed. Reply on this thread if you want a part that's not on the list and I'll add to the list and post a pic of it in the site linked in the original post.
73 240Z (LD28 swap project)
08 Mercedes Benz GL320CDI
Is the Driver Side power window switch warped? Are any of the tabs broken?
Ben Martin
Midnightz,
The oil filter base and oil cooler should come loose from the block as an assembly if I'm not mistaken. Also, Kassim503 is welcome to the upper fan shroud if it will fit his gasser. I am strongly considering an electric fan retrofit and might not need it much longer anyway. Thanks for taking the time to save this stuff from the scrapper!
If the driveshaft is good I'm sure somebody will want it. The 83 transmission is a rare bird too, but I understand storage and time constraints.
Re: Parting out 83 Maxima diesel wagon
See this post, and the drawing two posts below it.Midnightz wrote:oil filter base - goglio704
oil cooler - goglio704 (I didn't see an oil cooler... where would I see it?)
I'm sure they're quite SavageableThe driver window has been left open for at least a year so the driver seat and carpet are not savageable.
I did not catch this, but Matt did: what is the disposition of the transmission? Do I already have it? If not, and that Wagon does, I will buy it. Price depends on what you can tell me about it (if you haven't driven it, it's a core), but I'm definitely interested.
BTW, Kassim (and anyone else listening): I have a known-good '83 gasser OD AT that I no longer need, with TC. I will ship it (though shipping a trans is spendy). I want $150 for it. It came from a local '83 Sedan that got hit. I know the owner, he verified that it shifted fine. It's just sitting in my storage unit, slowly leaking on the paper towels from the cooler lines; I'd like it to find another home if someone wants it.
Driveshaft: if the joints aren't notchy, I would buy it as a spare. The Wagon driveshaft is different from the Sedan, but gasser & diesel are the same for each (er, I hope you can figure that out). I don't care about the condition of the support bearing.
The grill in the pictures doesn't appear to be for an 83, but the AC controls do. Maybe the grill is non original?
- Midnightz
Last call for parts you want on the parts car. I've just updated the linked site in the original post so look around. Planning on taking it to scrap yard Monday. I'll contact those in the list sometime next week on the claimed parts.
What damper? The damper at the passenger side engine mount? I saved both engine mounts.
the odometer shows 274k, so I am assuming the tranny has that much and I didn't drive the parts car. Core it is.asavage wrote:what is the disposition of the transmission? Do I already have it? If not, and that Wagon does, I will buy it. Price depends on what you can tell me about it (if you haven't driven it, it's a core), but I'm definitely interested.
I'll take some close-up pics of the tabs.83_maxima wrote:Is the Driver Side power window switch warped? Are any of the tabs broken?
I'll pull the PS pump and the brake booster tonight.asavage wrote:Save the PS pump, it's unique to the LD28 (not used on the gasser).
I see the damper's pulled. Hope you got that, it's a little harder to find than most, though they can be rebuilt if you have a core.
The brake booster is a 1983-diesel-only unit, because it contains the vacuum warning switch setup.
I need the washer reservoir and the snorkel (if not taken).
Ben Martin
Pretty sure Al was referring to the crank damper / vbelt sheave.Midnightz wrote:I'll pull the PS pump and the brake booster tonight.asavage wrote:Save the PS pump, it's unique to the LD28 (not used on the gasser).
If you don't need the washer pump too, I'd be interested in the pump.83_maxima wrote:I need the washer reservoir and the snorkel (if not taken).
You can have the pumps. Mine are good. Bottle is shot.goglio704 wrote:If you don't need the washer pump too, I'd be interested in the pump.83_maxima wrote:I need the washer reservoir and the snorkel (if not taken).
Ben Martin
