Diesel tachometer
Some random alternator notes:
In order to add this stator tap, you should have the rotor oil seal in hand before beginning. It should always be replaced. I would generically recommend brushes replacement too, because they're cheap and you have to R&R them anyway.
Getting the alternator out of the car (ie unbolting the vacuum pump from the alt's rear housing) is the worst of it. I'm lucky in that when I took it apart years ago, I installed socket-head 6mm bolts instead of phillips head, so I can use an allen wrench to remove the three horizontal bolts. If you can remove those three screws, leave the vacuum pump in the car, and leave all the oil and vacuum lines alone, it's a lot easier. But if the three phillips head screws won't come out, you'll have to disconnect the (5?) vacuum lines and both oil lines and take the thing out as an assembly.
The alt's lower front bolt (17mm head on mine) is easiest removed after slackening the alt belt. But both lower bolts should be tightened on installation.
I have stripped out the threads on the top (belt tension adjusting) hole on two of these things, so I automatically install an 8mmx1.25 helicoil in them while I have them out.
Check the diode pack for burned or broken output diodes (see the diode pictures in this post) . . . never mind, I'll copy the pics here, but the part No. info is there. Next two pics of an LR150 (SD engines):
These two pics are from the Nissan-supplied, Hitachi-rebuilt LR160 in my '82 Wagon, which failed about six weeks ago, due to this diode physically failing:
If you have the OEM diodes, strongly consider replacing it for the aftermarket style with more robust diodes (I have pics, but not processed yet; also have aftermarket part No.).
If the alternator's been rebuilt by someone other than Hitachi, it'll probably have the better diode assy. :roll:
On installation, the vacuum pump's rotor wants to slide out of position, making insertion of the rotor's splined shaft difficult, even though it's chamfered. I've found that rotating the rotor while inserting seems to spin the pump's rotor up into position and align the splines. Moderate pressure during insertion seems to help.
Every Hitachi LR series alternator that I've worked with seems to have some kind of bastard/universal noise suppression cap on the B+ terminal. I say "bastard" because the cap's ground fork doesn't seem to fit well no matter how you place it. I cut off the last 1/2" so the fork fits over the brush cover screw shank well. The chassis ground wire's lug also mounts to the same screw. If the ground lug is broken, don't neglect to install a new one; this is one of the body-to-engine grounds that keep the more sensitive electrics working correctly -- such as the temp gauge.
#17
Are those Clarks shoes? :wink:
No. I wore only Clarks shoes for twenty years, until they cheapened the sole material -- I still have a pair that I wear when going out, not at workaday stuff. Clarks were one of the few shoes still using stitched soles at the time.
Those are Target's house brand Cherokee shoes . . . which I can no longer seem to get. I throw away these cheap ($30-60) shoes about every six months. Silly, but it seems impossible to buy quality work shoes that don't look industrial, in the US now. I used to get two years out of a pair of $130 Clarks, with maybe one restitch in there somewhere for $10.
legacyelectric
#19
Post by legacyelectric »
HI all, I like the looks and feel of the tiny-tach. I want to buy one, but I want to make sure I get the right one would I want to buy the 6mm transducer or the 1/4 transducer
#20
legacyelectric wrote:HI all, I like the looks and feel of the tiny-tach. I want to buy one, but I want to make sure I get the right one would I want to buy the 6mm transducer or the 1/4 transducer
What kind of vehicle you drive? What's you name too? :wink:
Just scroll back to the very top and click on PROFILE. Then put those two item into the "Signature" box. That way we can be sure which transducer size you need. :wink:
asavage wrote:Getting the alternator out of the car (ie unbolting the vacuum pump from the alt's rear housing) is the worst of it. I'm lucky in that when I took it apart years ago, I installed socket-head 6mm bolts instead of phillip head, so I can use an allen wrench to remove the three horizontal bolts. If you can remove those three screws, leave the vacuum pump in the car, and leave all the oil and vacuum lines alone. It's a lot easier. But if the three phillips head screws won't come out, you'll have to disconnect the (5?) vacuum lines and both oil lines and take the thing out as an assembly.
Replaced the alternator in mine last week, and found it quite easy to disconnect the vacuum lines via the 24mm banjo bolt; this allows the fitting w/ all the small lines still connected to it to be moved out of the way sufficient for easy removal of the alternator w/ vac pump attached. Also disconnected the oil feed line at the rear of the vac pump by removing its banjo bolt, and the oil return line had a common worm drive hose clamp that was easily loosened. Plugging the oil ports w/ rubber stoppers minimized any oily mess while maneuvering the alternator/vac pump up and out thru the space between the air box/ intake manifold hose and radiator.
I remove the intake plenum hose entirely, leaving all the small hoses intact and connected on the engine. I unscrew the three pump-to-alternator screws, leave the pump on the engine and pull the alternator straight up. Only hard part is if you can't loosen the three pump-to-alternator screws, and getting the rotor shaft back into the pump on installation, which requires a little fiddling. Almost no oil loss.
legacyelectric
#23
Yea the car I just got going and want to use the tiny-tack is a 1982 maxima sedan 5 spd tranny
Larry Williams
All for sale
982 nissan 5 spd ld28 diesel Maxima sedan just got a new oem tranny installed runs great
1983 wagon ld28 with a 5 spd tranny just put in a new (junk yard) rear-end. runs great also
1982 mercedes 300d
1997 6.5 td 1 ton
1992 6.5 td 3/4 ton
too many others to mention
asavage wrote:I remove the intake plenum hose entirely, leaving all the small hoses intact and connected on the engine. I unscrew the three pump-to-alternator screws, leave the pump on the engine and pull the alternator straight up. Only hard part is if you can't loosen the three pump-to-alternator screws, and getting the rotor shaft back into the pump on installation, which requires a little fiddling. Almost no oil loss.
Thanks, Al, good to know this. If I read you correctly, this R/R alternator method requires a new rotor oil seal for sure, and isn't there also an o-ring to replace there too?
LD28 = 6mm injector lines (I just went out and measured one).
legacyelectric
#26
Thanks Al
Thats great to know
Larry
All for sale
1982 mercedes 300d
1997 6.5 td 1 ton
1992 6.5 td 3/4 ton
ecomike
#27
Post by ecomike »
Have any of you tried a Tiny Tach yet, if yes, how about some details?
I am thinking of ordering one. Does any one know the fuel line size on the SD22?
Mike
ecomike wrote:Have any of you tried a Tiny Tach yet, if yes, how about some details?
Zoltan has installed one on his 720. Continue any discussion of the the 720 tach over in that thread.
exmod110
#29
Post by exmod110 »
Y not just spend a bit o cash and get a universal type that has a magnet on the crank damper with a pick up that sends an accurate signal up to a matching gauge... I have one on my ld in my landrover... was under 200 at the time... was an easy install too!!
Tiny-Tach is US$65 (2005; $95 in 2013), including the pickup.
My alternator mod + tach is going to cost me under $60 (because I bought a very flexible tach from eBay, brand-new), and it's an air-core, analog unit with DIP switches for ranging adjustments, and a fine-tune pot too, plus free online tech support forum with someone who both knows his products well and can type in complete sentences: Beede.
"Under $200" can buy a lot of tach solutions, including yours.
Users browsing this forum: Google [Bot] and 23 guests
