Tuning with turbo (SD22 / '85 kc 4x4)
bacho
#46
Post by bacho »
On all our tractors and both the company PSD's if I start them with no glow plugs they all spit white smoke in the cold. The SD22 spits a cloud and then its done with that, black smoke comes when you push the motor to a hard load. Again all our diesels do that too. Not talking about lots of smoke here, but some.
1992 nissan pathfinder 4x4
1985 KC 720 4x4
1982 KC 720
#47
bacho wrote:SNIP- Again all our diesels do that too. Not talking about lots of smoke here, but some.
SD-2x are the only interests here. When misfires and/or visible smoke during engine loads, such are not optimal. :wink:
bacho
#48
Post by bacho »
I will try pushing the screw in a little to help the smoke. I found that it creates less smoke if I lay into the throttle easy, also builds boost better that way.
1985 KC 720 4x4
1982 KC 720
bacho
#49
Post by bacho »
Here is some videos of a guys Jeep who also runs an SD22, His is turboed in this video and I pretty much went along with his idea. I have a little less smoke than this. He has the smoke screw turned up with the waste gate set at 7psi.
http://mhdfl.com/forum/Videos/Turbo_Time.wmv
Here is a test at 20PSI boost. Wastegate simply pinched shut.
http://mhdfl.com/forum/Videos/Turbo_Time_2.wmv
He also tested a super charger on the SD22 but didnt like it.
http://www.mhdfl.com/forum/Videos/Super ... _test2.wmv
1985 KC 720 4x4
1982 KC 720
For an SD22, that's a LOT of smoke coming out of that Jeep. Mine smoke not at all under full load. 'Course, they're snails too. Black is almost always too much fuel for the air available. It's not good for us, either.
#51
bacho wrote:Here is some videos of a guys Jeep who also runs an SD22, His is turboed in this video and I pretty much went along with his idea. I have a little less smoke than this. He has the smoke screw turned up with the waste gate set at 7psi.
Smoke excessive or ... is it an old SeaBee Jeep? :wink:
bacho wrote:Here is a test at 20PSI boost. Wastegate simply pinched shut.
Like some old Skunt Train on hill rail?. :wink:
bacho wrote:He also tested a super charger on the SD22 but didnt like it.
Need less throttle coal and with THE RIGHT ignition timing.
More of same.
But nice mechanical works nice! :D
zen
#52
Post by zen »
blimey..with that much smoke i would get a pull by the police and ministry called...no dought vehicle impounded!!
plus all the green get rid of 4x4 brigade throwing abuse at me!!
turbo it
